EAGLE User Support (English) -N has no effect on promt suppression?
  • Subscribers 179 subscribers
  • Views 472 views
  • command
  • line
  • options
  • cli
  • cam
I'm hacking together some scripts to CAM process my boards automatically. My current command line looks like
> eagle -C " " -N- -X -d EPS some.brd -o some.tl.eps Top Pads Vias
EAGLE Version 6.4.0 Copyright (c) 1988-2013 CadSoft
CAM Processor: Encapsulated PostScript
Package 'PACK-SOT89' of element 'E$18' contains a polygon that may cause extremely large plot data.
Continue?
[Yes No](y):
> eagle -C " " -N+ -X -d EPS some.brd -o some.tl.eps Top Pads Vias
Continue?
[Yes No](y):
The problem here is that neither the '-N-' nor the '-N+' option does not what it is supposed to do according to the manual,
Yes, I tried both versions, because http://www.cadsoft.de/wp-content/uploads/2011/05/V6_manual_en.pdf says:
-N+ Suppress message prompts
but in the F1 help of my installation I can read:
-N- keine Rückfragen in der Kommandozeile
UPDATE: Just found out that the +/- inidcates the option's default – still wondering why the german and english version should have different defaults.
In fact I just need a way to tell eagle not to stop processing, but answer all questions with yes.
Moritz
  • dukepro
    0 dukepro over 12 years ago
    On 11/13/2013 05:10 AM, Moritz Augsburger wrote:
    I ran across the same thing somewhere in v5, and it has not been fixed
    in v6.
    , Yes, I tried both versions, because
    Try:
        echo n | eagle -C " " -N- -X -d EPS some.brd -o some.tl.eps Top Pads
        Vias
    echo -e "y\ny\ny\ny\ny\ny\ny\ny\n" | eagle -C " " ...
    7128.att1.html.zip
    0 Former Member over 12 years ago in reply to dukepro
    Will test this, but it looks good – except there is a little program called yes for this purpose:
    > yes | head
    y
    y
    y
    y
    y
    y
    y
    y
    y
    y
    So the better version of your solution should look like
    yes | eagle -C " " ...
    Thanks!
