EAGLE User Support (English) IDF export / generate 3d data
  • Subscribers 186 subscribers
  • Views 870 views
Hello all,
We are also working with Eagle for the electronic and with Solidworks for
the Mechenical parts.
From the Ulp's we have tried acis-sat.ulp and Generate_3d_data.ulp.
The acis-sat.ulp generates an rectangle with holes in it. The outline from
the PCB is not generated here . Also components are  not generated with this
ulp.
The Generate 3D data.ulp has the problem that it is not finished. After some
resurge we found out that the board outline is on layer 20 and that the line
need some thickness. If the thickness is 0 it is not working. Alse are some
things not implemented in the ulp. We changed some things and now we can
import the PCB correctly without the components into solidworks.
Now my question:
Is it possible that Cadsoft is doing some resurge and programming for a good
working export in IDF format.
All 3D software like , Unigraphics, Pro Engineer, Solidworks, Solidedge
Inventor etc. can import a IDF file.
I support the opinion from Mr. Fabio Mani that a IDF export  an important
choice is for working with Eagle.
Maybe it is possible for other user to react so an good working IDF export
can be set on the wishlist and Cadsoft can place it on the priority list .
With regards
Joop Sleumer
The Netherlands
LS:
The original discussion in on eagle.support.ger
    "Joop Sleumer" <joop.sleumer@pbfgroup.nl> a écrit dans le message de news:
    ggjmrf$vcm$1@cheetah.cadsoft.de...
    Hello all,
    this ulp.
    some resurge we found out that the board outline is on layer 20 and that
    the line need some thickness. If the thickness is 0 it is not working.
    Alse are some things not implemented in the ulp. We changed some things
    and now we can import the PCB correctly without the components into
    solidworks.
    Now my question:
    good working export in IDF format.
    Do you know an IDF viewer FREE (*.idb, *.idl)?
    With regards
    Joop Sleumer
    The Netherlands
    LS:
