EAGLE User Support (English) PCB image export problem
  • Subscribers 177 subscribers
  • Views 416 views
I worked with Eagle 5 for some years, and when I upgraded to version 6, I got a problem on exporting images.
I use a CNC milling machine for building my own prototypes, and I need images from PCB to generate CNC codes. The issue is the following: when I export a PCB image with the SET option DISPLAY_MODE as "REAL", the tracks "inside" the drill appear in the image. This is undesireble for me, because the circles of the drills should not be crossed. I put two images for comparing Eagle 5 and Eagle 6.
Is this behavior expected? How can I workaround this?
Yuri
Eagle 5:
Eagle 6:
