EAGLE User Support (English) eaglerc.usr
  • Subscribers 178 subscribers
  • Views 1540 views
eaglerc.usr
I do need to upgrade my EAGLE Pro to the V5. I don't want to buy a bug
fix but I have to.
I also need to maintain several V4 projects so I will leave both EAGLE
versions installed.
How to set the path of the eaglerc.usr file so each version can use its
own config file?
Marco Trapanese
Femtotech
Italy
  • Richard_H
    Richard_H over 17 years ago
    Marco Trapanese schrieb:
    fix but I have to.
    versions installed.
    own config file?
    Marco Trapanese
    Femtotech
    Italy
    EAGLE 4.1 stores the file eaglerc.usr in the folder
    "Documents and Settings/your username/My Documents"
    EAGLE 5 has a new location for eaglerc.usr. It's now stored in
    "Documents and Settings/your username/Application Data/CadSoft/EAGLE"
    If you install EAGLE 5 and start it for the first time it will
    look for eaglerc.usr in "Application Data/CadSoft/EAGLE". This
    file does not exist yet, so it looks also in "My Documents".
    So the settings of EAGLE 4.1 will be adapted.
    If you now change the settings (paths) in EAGLE 5 and quit EAGLE,
    eaglerc.usr will be stored in
    which is the default folder for EAGLE 5. Next time you start EAGLE5,
    the eaglerc file from "Aplication data" will be read.
    So you have different files for EAGLE 4.1 and 5.
    HTH
    Richard Hammerl
    "Richard Hammerl" <ric@cadsoft.de> schrieb im Newsbeitrag
    news:ggoah1$i2u$1@cheetah.cadsoft.de...
    I hope I assume right that you will step up to
    "Documents and Settings/your username/Application Data/CadSoft/EAGLE6"
    etc..
    T.
