EAGLE User Support (English) How to make "BRIDGE" parts library for single layer PCB manual routing?
  • Subscribers 178 subscribers
  • Views 568 views
I want to make "bridge" library with bridges for top layer for single
side manual ruting pcb. Part should have only one signal and two pads so
when put it on PCB, this pads it should be alredy connected. No manual
routing necessery
However, I make library with 2 pins witn names 1 and @1 and top layer
wire betwean, but it always show unconnected so I have to route this wo
pin again.
    Hej Mladen Bruck,
    There is allready a component for that problem. In the library Jumbers part
    J.
    But i suggest you just make it as a 2 layer pcb and where you want to make
    youre wire bridge you switch sides. When you make your'e pcb like a normal 1
    layer you can just connect those top wires with a real wire.
    Succes.
    "Mladen Bruck" <mladen.bruck@mocable.ba> schreef in bericht
    news:gh1qfv$1v7$1@cheetah.cadsoft.de...
    I want to make "bridge" library with bridges for top layer for single side
    manual ruting pcb. Part should have only one signal and two pads so when
    put it on PCB, this pads it should be alredy connected. No manual routing
    necessery
    However, I make library with 2 pins witn names 1 and @1 and top layer wire
    betwean, but it always show unconnected so I have to route this wo pin
    again.
    autodeskguest over 17 years ago in reply to autodeskguest
    Hi Ruud.
    Thank you for answer. Yes, I missed this part even I preview jumper
    library several times.
    My intention is to create library for standard long jumpers, so I can
    prepare bunch of real wire jumpers before making pcb.
    Even I thing to make small cutting mashine for manufacturing
    "industrial" jumpers image
    Regards!
    Hej Mladen Bruck,
    part J.
    make youre wire bridge you switch sides. When you make your'e pcb like a
    normal 1 layer you can just connect those top wires with a real wire.
    Succes.
    so when put it on PCB, this pads it should be alredy connected. No
    manual routing necessery
    wo pin again.
