EAGLE User Support (English) Gerber has missing pads
  • Subscribers 186 subscribers
  • Views 405 views
dionjohnson
dionjohnson over 17 years ago
I have been using Eagle 4.16 for several years and recently moved up to
Version 5.3.  I just completed my first design and when I was reviewing the
Gerber files I noticed that some of the SMT pads were missing on the copper,
solder mask, and paste.  One component is a 4 lead LED and is used 29 times
on the board.  Two of them have all four pads missing and the others are
fine.  Another is a 0603 resistor that is used 34 times and 7 of them have
the pads missing on the copper, solder mask, and paste layer.  Another 4 of
the 0603 resistors have the pads on the copper but no solder mask or paste.
I can't find any difference between parts that work and ones that don't.
They are the same library components with the same settings.
I am using the GERBER_RS274X output device.
Anyone have any ideas?
D Johnson
  • dionjohnson
    "Dion Johnson" <d.johnson@dakotadigital.com> wrote in message
    news:gh42lb$b6n$1@cheetah.cadsoft.de...
    copper, solder mask, and paste.  One component is a 4 lead LED and is used
    29 times on the board.  Two of them have all four pads missing and the
    others are fine.  Another is a 0603 resistor that is used 34 times and 7 of
    them have the pads missing on the copper, solder mask, and paste layer.
    Another 4 of the 0603 resistors have the pads on the copper but no solder
    mask or paste.
    D Johnson
    It looks as though the problem was actually just my Gerber viewer.  I have
    been using Camtastic 2000 for years with no problems until now.  I
    downloaded ViewMate and it looks fine.
    On Tue, 2 Dec 2008 14:42:49 -0600, "Dion Johnson"
    mask or paste.
    D Johnson
    Dion;
    You can always ZIP it and send it to FreeDFM.com.  FreeDFM generates
    check plots, and checks silkscreen problems, etc.  And, yes, it really
    is free.
    -Dave Pollum (a happy FreeDFM customer)
