EAGLE User Support (English) restrict on internal layer polygons
  • Subscribers 178 subscribers
  • Views 397 views
Is there a way to use a layer like trestrict for internal layer polygons?
cheers,
Jamie
  • Richard_H
    Richard_H over 17 years ago
    Jamie Morken schrieb:
    cheers,
    Jamie
    There are no special layers for rectric areas in inner layers.
    What you could do to achieve copper-free areas inside an inner
    layer polygon is to draw with the WIRE command (and width 0 or
    nearly 0) the edge of this area. If you now use RATSNEST the
    polygon will be calculated again and it will keep the given
    clearance value to the wires. The area inside will be kept free
    if the polygon's parameter "orphans" is set off.
    HTH
    Richard Hammerl
    cheers,
    Jamie
    These wires will possibly show up in the gerber data though, which isn't
    great, I guess if they are set to width 0 it will work probably, but I
    Am not sure how the gerber data will handle width zero wires.
    It would be great to have restrict layers for each routing layer I
    think, or a flag to say that the layer is a restrict layer, and for
    which corresponding layer.
    cheers,
    Jamie
    HTH
  • Richard_H
    polygons?
    cheers,
    Jamie
    cheers,
    Jamie
    HTH
    There was a discussion about this in the beta group recently.
    As far as I remember there will be a solution for a future version.
    Wires with a width of 0 normally don't appear in the Gerber data.
    To be sure what will happen contact your board manufacturer.
    Richard Hammerl
    "Richard Hammerl" <ric@cadsoft.de> a écrit dans le message de news:
    gh7vgs$unv$2@cheetah.cadsoft.de...
    polygons?
    cheers,
    Jamie
    cheers,
    Jamie
    HTH
    Yes! in <eagle.suggest.eng> vRestrict on Inner Polygons, Klaus said:
    we introduce a new polygon "Pour" style named "invers" or "negative"...
    This is a very good (future) news, but for which version: V5 or V6 ?
    cb
    Richard Hammerl
