EAGLE User Support (English) No Air wire in the board using SMD resistor and LED
  • Subscribers 180 subscribers
  • Views 564 views
  • eagle
Dear Sir
I am new to Eagle,
No Air wire in the board using SMD resistor and RGB LED
How to solve?
    0 autodeskguest over 12 years ago
    On 5/01/2014 5:51 p.m., Robert Law wrote:
    Dear Sir
    I am new to Eagle,
    How to solve?
    http://www.element14.com/community/message/99521
    Greetings.
    You attached .PNG so what follows is a guess. Had you attached the
    schematic and board the answers would be definite.
    A schematic must have a grid of 0.1 inch.
    You may have used WIRE instead of NET to perform the interconnections.
    The PNG suggests the nets have not connected to the pins of the parts,
    move the parts and if the nets stay behind, this is your problem.
    Hope this helps
    Warren
    0 Former Member over 12 years ago in reply to autodeskguest
    Dear warrent,
    Thanks your reply.
    I using the NET to connect.
    And using the same "NAME" on both ends.
    LED.zip
    0 autodeskguest over 12 years ago in reply to Former Member
    On 5/01/2014 8:48 p.m., Robert Law wrote:
    Dear warrent,
    Thanks your reply.
    http://www.element14.com/community/message/99504
    LED.zip
    The problem is the parts are not on the grid and therefore the pins are
    not either. Because of this the nets will not connect to the pins of the
    parts. If you display the grid you can see this easily.
    To get the parts and their pins back onto the grid, move the part, but
    before you select the part hold down the CTL key. This will cause the
    part to jump to the grid as you click on it. Then re-make the nets.
    You can test that all is well, when you have finished, by moving a part
    and its nets will stay attached and stretch so that they can remain
    attached.
    HTH
    Warren
    Hi Warren,
    Now all on the net but still no airwire on board between SMD resistor and LED.
    1768.LED.zip
    On 6/01/2014 2:24 a.m., Robert Law wrote:
    Hi Warren,
    and LED.
    http://www.element14.com/community/message/99565
    LED.zip
    The nets still were not attached to the parts.
    I have returned your schematic/board (Attached) where, in the schematic
    I have
    (1) Moved your LEDs resistors and IC so you can see the unattached nets
    (2) Copied your resistors and leds and added nets.
    Move my resistors and LEDs and you will see the nets stay attached.
    Your problem is common, You cannot simply move a net up to a part and it
    will attach. It may look good but remember Eagle is not simply  a
    drawing program.  You net to move a net up to a pin.
    There are two ways to verify the connection.
    Move the part:
    (1) Left click on the MOVE icon
    (2) Click on the part origin and move it around so you can verify the
    nets stay attached.
    (3) While still moving the part you can hit ESC and the part will go
    back to its original position.
    The other way is to
    (1) Left click on the SHOW icon
    (2) Left click on your net and it will become bright green. If it is
    attached to a pin then that pin will become bright red
    All the best
    Warren
    LED2.zip
