EAGLE User Support (English) Eagle 6.5 network installation
  • Subscribers 185 subscribers
  • Views 450 views
Hi
I’m implementing eagle for my company. I bought license for 3 users.
Is it possible to install eagle on a server and allow users to use it through network share?
If yes, how should I do it?
If not, is there any way to achieve that?
I’d like to avoid local installation on a specific pc because in my company pc's and employees change quite often.
    0 autodeskguest over 12 years ago
    Am 07.01.2014 10:14, schrieb Lukasz Tefal:
    Hi
    http://www.element14.com/community/message/99779
    from the manual...
    Notes for Installing in a Network
    The user rights of multipleuser licenses differ from those of the
    singleuser version. The software itself does not contain any
    special network mechanism, and can therefore be used on most networks.
    A typical installation may be performed as the following:
    The EAGLE program is installed on a server.
    Library, design, ULP, project and other directories can be freely
    chosen. After installation, EAGLE is started and licensed from one
    of the workstations. This requires write access in the subdirectory
    bin of the EAGLE directory. The license file eagle.key that has been
    created is not changed  again after the installation. Write access
    is no longer required.
    EAGLE can now be called from all the other workstations.
    Please ensure that all the workstations call EAGLE in the same way
    as it was used when licensing.
    A private working directory (local or on the network) can now be set
    up for each computer. A userspecific configuration file (eaglerc.usr
    under Windows, or .eaglerc under Linux or Mac OS X) is located in
    this directory. Further subdirectories can then, for instance,
    contain individual projects.
    HTH
    Richard Hammerl
