EAGLE User Support (English) Hole Schedules and Excellon drill with non-plated holes
  • Subscribers 179 subscribers
  • Views 1019 views
My design has multiple instances of a hole dia as both plated and non-plated holes.
The schedule table shows the items and quantity for each, but uses the same symbol for both of them. It should have different symbols.
This then carries into the Excellon outputs, and it lumps all the xy coord for plated and non-plated drills into one tool. It should have separate tools and there should be means to generate separate drill files for plated and non-plated holes.
Any solutions would be appreciated.
    0 autodeskguest over 12 years ago
    non-plated holes.
    The symbols are for the drill diameter. Same diameter, same symbol.
    I suggest this is not needed. The board houses have rules that take care
    of that for you.
    You need to design in your chosen CAD product with an understanding of
    the manufacturing process. There is only one excellon (drill) file
    provided to the board house and yet they can deliver what you want with
    no other conversation if you design your board to their rules.
    For example check out Eurocircuits design-guideline document, section on
    Holes, for an understanding. PCB-Pool quotes something similar
    http://www.eurocircuits.com/images/stories/ec13/ec-design-guidelines.pdf
    The right combination of hole and copper or no copper will attain a PTH
    or non-PTH hole as required.
    HTH
    Warren
    http://www.element14.com/community/message/101600
    Am 21.01.2014 07:33, schrieb Jack Gratteau:
    non-plated holes.
    As Warren already wrote: The symbols represent the drill diameter...
    EAGLE knows "drills" as they are used in pads and vias (plated) and
    holes placed with the HOLE command (non-plated). If you prefer to have
    two separate drill files, you could use the CAM Processor and let it
    create an Excellon file for the Drills layer and one file for the
    Holes layer.
    In general the board manufacturer decides about plated or non-plated:
    That's very simply. If a drilling is surrounded by copper it is
    possible to make it plated. If it is not in an copper area, it is
    simply impossible to make it plated.
    Richard Hammerl
    0 autodeskguest over 12 years ago in reply to autodeskguest
    non-plated holes.
    ... snip ...
    On which point I would note that some board houses explicitly request
    that you don't do that. You tell them which drill codes (=sizes) are PTH
    and which are non-PTH, you can't define it on a per-hole basis.
    non-plated holes.
    ... snip ...
    All good information. I wonder, how those board house handle the board
    of the OP where there are the same sized hole, some PTH and others not.
    As always, cater to the requirements of the board house.
    Regards
    Warren
