EAGLE User Support (English) distance and drill errors on vias
  • Subscribers 178 subscribers
  • Views 425 views
I have a completed my first board, a 2 layer board, and it involves a few vias. The lands are all 16 mils. Regardless of how the lands meet - 0 or 90 degrees, I have distance and drill DRC errors on every land joining via. The board has ground polygons on top and bottom and the vias that connect the top and bottom do not report errors.
I've read many things and tried quite a few of the suggestions and I've got to be missing something.
Help!
mark
    On 22/01/2014 4:06 p.m., Mark Bellon wrote:
    I have a completed board layout that involves a few vias. I've got many
    DRC errors, all pointed at the vias. The lands are all 16 mils
    mark
    http://www.element14.com/community/message/101728
    FYI Not all of your post at Element 14 got to the Eagle Newsgroup.
    That aside. Check the names of the vias are the same as the traces and
    the size of the via drill is greater than that set for vias in the DRC.
    HTH
    Warren
    Hello Mark,
    I think you need to check your grid setting on the board layout.
    Make sure your grid setting is a lot greater than your via drill measurement.
    You may attach your schematics if this is not clear to you.
    Good luck,
    Jude
