EAGLE User Support (English) Eagle changes the selected track width while selecting a diferential airwire for routing
  • Views 651 views
zainka
zainka over 12 years ago
Hi
In my design there are several differential signals, each named with _N/_P at the end. I have also created a class for these signals, and yes I have assigned the differential nets to this class, The class has the width set to 6mil. Now, When I select the route tool i manually set the width to 6mil as-well but whenever I select a differential air-wire to rout the track width changes to 10mil automatically. I may change it manually back to 6mil again and continue routing, but the next time I select a differential track it switches back to 10 mil.  This is irritating at best and I have never seen this behavior before. Surly it must be some simple setting I have gotten wrong but I cant figure out what.
I have rechecked and checked again that the class is set correctly and I have used classes many times before without having this problem. I cant see any problems in the DRC setup either.
Any suggestion for where to look?
    0 e14 Contributor over 10 years ago in reply to autodeskguest
    I know it s a little bit late but i belive if any people will face this problem again like me here is my solution.
    Options > Set > Misc > uncheck the "Auto set route width and drill" checkbox.
    So what coused this problem? I think i probably missclick this button accidently. Because i can hit checkbox button from outside of chechbox.
    0 autodeskguest over 12 years ago
    "vidar vidnes" <vidar.vidnes@yahoo.no> a écrit dans le message de news:
    488765617.241390463228745.JavaMail.jive@flmspu-csapp-02.premierfarnell.com...
    Hi
    N/P at the end. I have also created a class for these signals, and yes
    what.
    Just have a look for the field 'Minimum Width' under the 'Sizes' tab in DRC
