EAGLE User Support (English) hole placement error
  • Subscribers 177 subscribers
  • Views 221 views
I have a hole that was called by the mechanical drawing to be at .1563" when I assign that coordinate Eagle gives me .15629995" - why can't it simply let me place it where I want? I'll admit this is a VERY trivial error, but it IS still an error. If I assign dimension values that are multiples of .000125" everything is okay.
    John Knittle wrote on Fri, 24 January 2014 10:20
    .1563"
    From the manual
    EAGLE performs its internal calculations using a basic grid size of
    0,00325 μm (about 0.000123 mil).
    So, your .1563" gets converted to the nearest internal unit (metric) and
    then the units are calculated back to inches when it needs to be displayed
    in inches.
    HTH
    Warren
