EAGLE User Support (English) Eagle 6.5.0 in Debian 7 64-bit
  • Subscribers 189 subscribers
  • Views 1317 views
bigguiness
bigguiness over 12 years ago
I thought I would take a look at Eagle but I cannot get it to install on my Debian 7 64-bit system.
Running the downloaded eagle-lin-6.5.0.run installer I get:
$ cd /tmp
$ wget ftp://ftp.cadsoft.de/eagle/program/6.5/eagle-lin-6.5.0.run
$ chmod +x eagle-lin-6.5.0.run
$ ./eagle-lin-6.5.0.run
/tmp/eagle-setup.9733/eagle-6.5.0/bin/eagle: error while loading shared libraries: libXrender.so.1: cannot open shared object file: No such file or directory
It appears that Eagle needs some 32-bit libraries but I don't think these are available on Debian 7 64-bit.
Any ideas?
Hartley
    0 e14 Contributor over 12 years ago in reply to Richard_H
    Dose installation successful?
    I also plan - install hobbist version under virtual machine, but also have 64bit and on Mac I have already installed light version, they can't work together.
  • Richard_H
    0 Richard_H over 12 years ago in reply to ocwo92
    I think the following packages are needed:
    sudo apt-get install libxrender1:i386
    sudo apt-get install libxrandr2:i386
    sudo apt-get install libxcursor1:i386
    sudo apt-get install libfreetype6:i386
    sudo apt-get install libfontconfig1:i386
    sudo apt-get install libxi6:i386
    sudo apt-get install libpng12-0:i386
    sudo apt-get install libstdc++6:i386
    sudo apt-get install libjpeg62:i386
    HTH
    Richard
  • ocwo92
    0 ocwo92 over 12 years ago in reply to autodeskguest
    After adding the architecture, you'll need to install the i386 libraries:
    sudo apt-get install libxrender1:i386 libxrandr2:i386 libxcursor1:i386 libfreetype6:i386 libfontconfig1:i386 libxi6:i386 libssl1.0.0:i386
    and possible some more.
    0 autodeskguest over 12 years ago
    $ cd /tmp
    or directory
    Any ideas?
    Hartley
    http://www.element14.com/community/message/102308
    Hi Hartley,
    On 64-bit machines, EAGLE needs a 32-bit environment to be setup. Try
    the procedure referenced below:
    sudo dpkg --add-architecture i386
    sudo apt-get update
    Some additional info can be found here
    http://fwroller.com/2013/05/07/how-to-run-32-bit-apps-on-ubuntu-13-04-64-bit/
    Best Regards,
    Jorge Garcia
