EAGLE User Support (English) Eagle library
  • Subscribers 179 subscribers
  • Views 446 views
Eagle library
I am using TBA810 audio amplifier in one of my projects but i am not getting eagle library for the same
Can anybody help me regarding this
  • saurocksall
    0 saurocksall over 11 years ago
    Hi Satish,
    i looked for the Eagle lib on the net but it's not there, it's a commonly used ic still no eagle library strange...
    i would suggest to use other software or ic...
  • adrewery87
    0 adrewery87 over 11 years ago
    You can create practically any part you would like using Eagle CAD.  The tutorial I used when I first started using Eagle is linked below.  To determine the pad size refer to the datasheet.  The package layout will likely be contained within the datasheet, and is commonly referred to as the land pattern or it will explicitly say something to the effect of "recommended PCB layout."  The symbol can be whatever you would like it to be.  Once you create both the package and the symbol you will need to link them together through the device.  Hope this helps.
    How to Create Part in Eagle CAD - YouTube
