EAGLE User Support (English) IRF540 Vertical mounting
  • Subscribers 178 subscribers
  • Views 660 views
donrecardo
donrecardo over 11 years ago
Hi ,
   I am very new to eagle and am trying my first PCB
I need to mount an IRF540 Mosfet which I have found in the library , but it mouts it horizontal on the
PCB  but I need ot to be vertically mounted , What is the easiest way to do this, remembering I am a beginner
Thank you
Don
    On 30/01/14 19:58, Don Recardo wrote:
    Hi ,
    First, take a copy of the 'transistor-fet' library and put it somewhere
    you can edit it without danger of being overwritten by an upgrade.
    Next, open that library for editing and select the IRF540 device. Click
    the "New" button near the bottom right and select the 'TO220V' package.
    You need to type in a variant name before clicking OK.
    Then click "Connect". On the dialogue, click the empty "Copy from"
    drop-down and pick the only option available. Then click OK.
    Alternatively, create a new custom library and copy just those two items
    (the IRF540 and the TO220V) into it. You can do this by dragging from
    the control panel (although you can't drop the package when a device is
    open, so open a symbol instead). Then add the package as above.
    That's it. If you use the part from that modified library you can change
    the package to the vertical one.
    Cheers,
    Rob
  • donrecardo
    0 donrecardo over 11 years ago in reply to autodeskguest
    Hi Rob
    Many thanks for your answer. It worked just as you said it would so I now have my IRF540 with vertical mounting
    What's more important is I will now know how to do it for other library items too
    Thank you again for your help
    Don
