EAGLE User Support (English) Silkscreen parts outline runs past edge of board, not helpful when pannelizing board
  • Subscribers 180 subscribers
  • Views 309 views
  • eagle
  • silkscreen
  • edge
airshipcrew
airshipcrew over 12 years ago
I am using Eagle 5.12 and am now starting to pannelize boards.  When I have done single boards in the past I never worried about parts outlines on the silk layer running past the board edge as long as the parts are mechanically secure.  Now I am putting the boards into arrays and the parts outlines which normally would simply have been clipped at the board edge are now running off the edge of the board onto a neighbouring board.  Is there any utility or user language program that will remove the silk that runs off the board edge?  I don't want to alter the parts themselves as I use them elsewhere and may want to have the full silk outline at some times.  I realize this does not affect the functionality of the board but does make it a little less professional looking.
  • Richard_H
    0 Richard_H over 12 years ago
    if you would like to have a proper silkscreen you have change the library definition.
    If you don't want to change the original libraries, you could export the library definition from your board into "working libraries", change the packages and update your design.
    For exporting take exp-projects-lbr.ulp.
    HTH
    Richard
