EAGLE User Support (English) How to change font size throughout brd
  • Subscribers 189 subscribers
  • Views 10362 views
How do I change the font size for all of my component values and names on my brd.  I would rather not go to each individual one to do this.  I looked for a ULP and searched the forum and couldn't find an answer.
  • dukepro
    0 dukepro over 12 years ago
    It's better to do this from a script.
    Try these commands:
        display torig borig;   # Display the top and bottom origins
        group all;             # Group everything
        smash (C>0 0);         # Smash everything in the group
        display none tname bname tval bval; # OPTIONAL: limit changes to
        names and values
        group all;             # Group everything including smashed texts.
        change font vector (C>0 0); # Change the font to a vector font
        change size 50mil (C>0 0); # Change the font size
        change ratio 15 (C>0 0); # Change the width:height ratio
        display last;
    The "(C>0 0)" above represents a control-Right click at the origin,
    which performs the operation on everything in the currently selected group.
    If you save the above into a script myScriptName.scr, you can run it
    with a single command "SCR myScriptName".
    Set the ratio so that the line width is equal to or larger than the
    minimum silkscreen line width as published by your board house.  In the
    above case, the line width would be 50mil * 15% = 7.5 mils.
    HTH,
        - Chuck
    5047.att1.html.zip
    Hey
    Use  change! It looks like a wrench.
    Mogens Dreier
