EAGLE User Support (English) Gerber output format
  • Subscribers 178 subscribers
  • Views 512 views
SpacedCowboy
SpacedCowboy over 17 years ago
Hi there,
I've just acquired a rather nice EverPrecision 2002H PCB plotter, and
I'm trying to get Eagle to output the correct form of Gerber files that
the plotter understands.
I think it's the aperture file that's causing problems....
- If I use the supplied example gerber top file, and the supplied
example aperture file, the machine plots out the example circuit just
fine and dandy (well, duh! image
- If I use the eagle-generated aperture file (*.whl) and the
eagle-generated gerber top-layer file, I get a black screen in the
control-software. No lines anywhere
- If I use the eagle-generated gerber top-layer file and the supplied
example aperture file, I at least see something. It's a bit weird, but
there are lines on the screen.
I conclude that (at least) the aperture file is not being read
correctly. Inspecting the two files (the example one, and the
eagle-generated one) shows quite a different file format... Here's the
example one:
simon% cat Demo.apt
D11   ROUNDED            12.000      12.000       0.000 MULTI
D12   ROUNDED            50.000      50.000       0.000 MULTI
D13   ROUNDED            60.000      60.000       0.000 MULTI
D14   ROUNDED            48.000      48.000       0.000 MULTI
D15   RECTANGULAR        24.000     100.000       0.000 MULTI
D16   RELIEF             20.000      20.000       0.000 FLASH
D17   ROUNDED            20.000      20.000       0.000 MULTI
D18   RECTANGULAR        34.000     110.000       0.000 MULTI
D19   RECTANGULAR       100.000      24.000       0.000 MULTI
D20   RECTANGULAR       110.000      34.000       0.000 MULTI
D21   OVAL              24.000     100.000       0.000 MULTI
D22   OVAL              34.000     110.000       0.000 MULTI
D23   ROUNDED             6.000       6.000       0.000 MULTI
D24   ROUNDED            10.000      10.000       0.000 MULTI
D25   RELIEF             52.000      52.000       0.000 FLASH
D26   ROUNDED            52.000      52.000       0.000 MULTI
D27   RECTANGULAR        50.000      50.000       0.000 MULTI
D28   RECTANGULAR        60.000      60.000       0.000 MULTI
D29   ROUNDED             5.000       5.000       0.000 MULTI
... and here's what Eagle outputs for my test-the-plotter  circuit:
simon% cat digi.whl
;aperture wheel file generated by EAGLE
;remove the above line to prevent this file from being overwritten!
D10      draw      0.0000inch
D11      draw      0.0030inch
D12      round     0.0560inch
D13      round     0.0620inch
D14      draw      0.0050inch
D15      draw      0.0020inch
D16      square    0.0560inch
D17      square    0.0620inch
D18      octagon   0.0560inch
D19      octagon   0.0620inch
D20      draw      0.0060inch
D21      draw      0.0040inch
D22      draw      0.0480inch
D23      draw      0.0540inch
D24      draw      0.0560inch
D25      draw      0.0620inch
D26      round     0.1360inch
D27      rectangle 0.0350inch x 0.0500inch
D28      draw      0.0632inch
D29      draw      0.0692inch
D30      draw      0.0100inch
D31      rectangle 0.7300inch x 0.0300inch
D32      rectangle 1.2200inch x 0.0200inch
D33      round     0.2000inch
D34      round     0.2060inch
D35      rectangle 0.0320inch x 0.2850inch
D36      rectangle 0.0320inch x 0.1850inch
D37      octagon   0.0480inch
D38      octagon   0.0540inch
D39      rectangle 0.0240inch x 0.0340inch
D40      rectangle 0.0200inch x 0.0150inch
D41      rectangle 0.0150inch x 0.0200inch
D42      draw      0.0700inch
D43      draw      0.0760inch
D44      square    0.0593inch
D45      square    0.0653inch
D46      round     0.0593inch
D47      round     0.0653inch
D48      round     0.0240inch
D49      round     0.0300inch
... the file-formats are quite clearly different, and presumably the
machine's software isn't sufficiently flexible to parse the output
correctly. I think the machine is expecting 'protel' aperture-file
syntax.
So:
- Is there any way of altering the format of the wheel file generated
by eagle ?
- Is there any place I can read up on how I might run a perl script to
convert between the two formats ?
- Is there an easier way ? Or am I just missing something ? This is the
first time I've played with Gerber output...
Thanks for any help
Simon
    Former Member over 17 years ago
    Simon,
    Just curious.... can you just export in extended Gerber format so that the
    apertures are embedded, or do you need the separate aperture list for the
    plotter?
    Terri
    "Simon" <simon.gornall@mac.com> wrote in message
    news:gimubd$hl0$1@cheetah.cadsoft.de...
    Hi there,
    example one:
    simon% cat Demo.apt
    simon% cat digi.whl
    D10      draw      0.0000inch
    D11      draw      0.0030inch
    D14      draw      0.0050inch
    D15      draw      0.0020inch
    D20      draw      0.0060inch
    D21      draw      0.0040inch
    D22      draw      0.0480inch
    D23      draw      0.0540inch
    D24      draw      0.0560inch
    D25      draw      0.0620inch
    D28      draw      0.0632inch
    D29      draw      0.0692inch
    D30      draw      0.0100inch
    D42      draw      0.0700inch
    D43      draw      0.0760inch
    syntax.
    So:
    by eagle ?
    Thanks for any help
    Simon
    On 2008-12-26 07:39:14 -0800, "Terri Miller" <tmiller@sunstone.com> said:
    Simon,
    the apertures are embedded, or do you need the separate aperture list
    for the plotter?
    Terri
    I should have updated the post - once I realised I could use RS274X
    instead, everything went swimmingly image I even set up a web-page to show
    off the results, I was so pleased (see http://www.0x0000ff.com/2002H/
    for examples of 0.5mm traces/pads).
    So, everything is great image
    Cheers,
         Simon.
