EAGLE User Support (English) Looking for relay FSMR
  • Subscribers 178 subscribers
  • Views 503 views
Hi all,
In a design I used the relay out of the Eagle library which is called FSMR. This seems to be very stupid, because I can't find a relay that fits this footprint. The PCB is already been produced. Stupid, stupid me !
Can anyone help me finding a relay that fits?
Best regards,
Mischa
    On 11/02/2014 1:19 a.m., Mischa Gielen wrote:
    Hi all,
    Here's an idea. You posted this request at Element14, they sell relays
    you know.
    Try their part number 9480137
    It looks like it will fit but its up to you to select the coil voltage
    and contact current that suits your design. This is only the first I
    found. There will be many others. Google "relay cross reference" and you
    get numerous results with many references to the FBR21D/H, Fujitsu
    moddel mentioned in the FSRM library part. Then you only have to choose
    one of the many mail suppliers that works for you.
    Good luck
    Warren
    0 Former Member over 11 years ago in reply to autodeskguest
    Warren, you are a genius ! Thank you very much. I was searching the element14 program for 2 days, but couldn't find this relay.
    Thanks again.
    Mischa
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Hi all,
    you know.
    Good luck
    Warren
    Actually that relay 9480137 does not have the correct pin out so will
    not do, but you get the idea. You should be able to locate one.
    The relay I was looking for (and which I found with your help) unfortunately wasn't capable of switching the current I need. Just my stupid mistake to choose any relay. Now I glued a larger relay to the pcb and connected it with wires.
    So problem solved !
