EAGLE User Support (English) how do I create a button text ?
  • Subscribers 178 subscribers
  • Views 784 views
    Am 17.02.2014 19:13, schrieb Barry Bickerton:
    Just write it down when creating the button:
    dlgPushButton("This is the button text");
    A complete working (but useless) ULP:
    dlgDialog(filename(argv[0])) {
    http://www.element14.com/community/message/104053
    0 Former Member over 11 years ago in reply to autodeskguest
    OK So how do you create a toolbar button (I have seen some people referring to these buttons as button texts) hence the incorrect question
    0 autodeskguest over 11 years ago in reply to Former Member
    http://www.element14.com/community/message/104141
    The MENU command will accomplish this. Make sure you have 'Command Texts' enabled in the User Interface options. From inside eagle, type 'HELP MENU' for a detailed description.
    Here's the schematic section of my eagle.scr file that uses command texts and context menus.
    Hope it helps.
    #+################################## SCHEMATIC ################################
    SCH:
    Grid mil 100 alt mil 12.5;
    Grid Lines;
    Grid OFF;
    USE -* /home/estevens/repos/library/Eagle6/LBR;
    USE    /home/estevens/repos/library/Eagle6/LBR/ruler;
    USE    /home/estevens/repos/library/Eagle6/LBR/adc_dac;
    USE    /home/estevens/repos/library/Eagle6/LBR/connectors;
    USE    /home/estevens/repos/library/Eagle6/LBR/crystals;
    USE    /home/estevens/repos/library/Eagle6/LBR/diodes;
    USE    /home/estevens/repos/library/Eagle6/LBR/transistors;
    SET PALETTE BLACK;
    SET COLOR_GRID 8;
    SET XREF_LABEL_FORMAT '%F%N (p%S)';
    Assign C+F 'run xfind.ulp;'
    Assign C+M 'script smash_all.scr;'
    SET MIN_TEXT_SIZE 0;
    SET Warning.PartHasNoUserDefinableValue 0;
    SET CONTEXT text;
    SET CONTEXT text 'Change text' 'change text';
    SET CONTEXT instance
    SET CONTEXT instance 'Fix Text'      'run eas-fix_name_value_pos';
    SET CONTEXT instance 'Mark Symbol'   'run eas-mark_here';
    SET CONTEXT instance 'Add Tolerance' 'run eas-add_attribute tolerance';
    SET CONTEXT instance 'Add Voltage'   'run eas-add_attribute voltage';
    SET CONTEXT instance 'Add Wattage'   'run eas-add_attribute wattage';
    SET CONTEXT instance 'Add Attribute' 'run eas-add_attribute';
    Set Used_Layers 91 92 93 94 95 96 97 98;
    Display All -93 -98;
    Change Width 6;
    Change Font proportional;
    change Size 56;
    Change Ratio 8;
    #+ Command Menu Setup
    MENU
      '100/12.5           : Grid mil 100 alt mil 12.5'\
      'Notes              : Change Size 56; Change Ratio 2; Change layer Info; Change linedistance 80; Change align top left; Text'\
      'Last               : Grid last;'\
      'On                 : Grid On;'\
      'Off                : Grid Off;'\
      'Smash All          : script smash_all.scr'\
      'BOM                : run bom_gdi.ulp'\
      'Change Group Value : run gdi-change-value-group'\
      'Clean Up Text      : run eas-fix_name_value_pos'\
