EAGLE User Support (English) How can I send a command "display none 17" from inside a ULP?
  • Replies 11 replies
  • Subscribers 181 subscribers
  • Views 1332 views
lenaveryt
lenaveryt over 11 years ago
I'm trying to create a ULP that will automatically generate a DXF file with only specific layers turned on.
I want these hard coded inside the ulp.
I'm basicly modifying the DXF.ulp to only generate layers 17,20,31,121
    Hi Leonard,
    I suspect you may need to have a script file that sets the visible layers and execute the script from the ULP at the relevant point.
    If you have eg. make_my_layers_visible.scr  with the line
    DISPLAY NONE 17 20 31 121
    in it and then in the ULP use,
    system("SCRIPT ' "make_my_layers_visible.scr" ';");
    I haven't tried this so no guarantee it'll work like this but it's what I'd try if it was me image
    HTH,
    http://www.element14.com/community/message/104172
    Like this:
    string cmd[];
    int idx = 0;
    if (board)
      board(B)
        cmd[idx++] = "DISPLAY NONE 170;";
        cmd[idx++] = "GRID ON;";
    exit(strjoin(cmd, '\n'));
  • dukepro
    0 dukepro over 11 years ago in reply to autodeskguest
    Like this:
    string cmd[];
    int idx = 0;
    if (board) {
        // Make sure the correct layers and grid are set going into this ULP.
        // If the first argument is not "gridIsSet", then we need to set
        // the display and grid environment and re-invoke this ULP.
        // This assumes that the name of this ULP is "myDXF.ulp".
        if (argv[1] != "gridIsSet") {
            // Setup the display, the grid, and re-invoke this ULP with an
        argument
           exit("display none 17 20 31 121;\ngrid on;\nrun myDXF gridIsSet;\n");
      board(B)
           // Other code to produce a DXF goes here.
    77862.att1.html.zip
    0 autodeskguest over 11 years ago in reply to Former Member
    Daniel Wainwright wrote:
    Hi Leonard,
    no, that won't work. The system command launches other applications
    outside of eagle. It can not control the running instance of eagle.
    scripts or command strings can only be executed using the exit
    command.
    Lorenz
    0 Former Member over 11 years ago in reply to autodeskguest
    Thanks for pointing that out, seems rather obvious in hindsight. image
    How does control return to the ULP after eagle executes the command given in the exit() function though?
  • AnalogNotes
    0 AnalogNotes over 11 years ago in reply to Former Member
    It doesn't.  image
    Why not do things the other way around and run a script first and call the ULP from that, something like:
    display none 17;
    run dxf.ulp;
    display last;
    You could even assign that to a button with the menu command.  Or did I completely miss the point?
    0 Former Member over 11 years ago in reply to Former Member
    I need my glasses adjusted or something....
    I now see the 'run MyDXF' bit in:-
    Chuck
  • lenaveryt
    0 lenaveryt over 11 years ago
    I haven't tried anything but the following. It does turn off the layers I don't want but exits the UPL. I need to add the check and reinvoke the ulp  like chuck suggested.
    If that doesn't work I may just do a script as was suggested.
    // Main program: / FROM original DXF.ULP by Dr. L. Rossipaul Verlagsgesellschaft m.b.H
    string OutputFileName;
    int DoDialog = argc == 1;
    string FileNameSuffix;
    for (int i = 1; i < argc; i++) {
        if      (argv[i] == "-s") FileNameSuffix = argv[++i];
        else if (argv[i] == "-u") {
                                    string u = strupr(argv[++i]);
                                    if (u) {
                                       if (u == "MM")
                                          Unit = MM;
                                       else if (u == "INCH")
                                          Unit = INCH;
                                       else {
                                          dlgMessageBox(usage + tr("<hr><b>ERROR: unknown unit: ") + argv[i] + "</b>");
                                          exit(1);
                                    else {
                                       dlgMessageBox(usage + tr("<hr><b>ERROR: missing <i>unit</i></b>"));
                                       exit(1);
        else if (argv[i] == "-a") AlwaysVectorFont = YES;
        else if (argv[i] == "-w") UseWireWidths = YES;
        else if (argv[i] == "-f") FillAreas = YES;
        else {
           dlgMessageBox(usage + tr("<hr><b>ERROR: unknown option: ") + argv[i] + "</b>");
           exit(1);
    string cmd[];
    int idx = 0;
    if (board)
      board(B) {
      cmd[idx++] = "DISPLAY NONE 17 20 31 121;";
      exit(strjoin(cmd, '\n'));OutputFileName = B.name;/ <- ********* always exits the ULP here.
         B.layers(L) {
           string s = L.name;
           if (L.visible && s[0] == '$') {
              VisibleSupplyLayer = YES;
              IsSupplyLayer[L.number] = YES;
    else if (schematic)
       schematic(SCH) OutputFileName = SCH.name;
    0 autodeskguest over 11 years ago in reply to lenaveryt
    exit() will always exit the running ULP. The reentry method Chuck suggested is a good approach to running multiple process steps via a single ULP. I wouldn't split up a chunk of code unless you plan on reusing the SCR for other purposes. Why have to maintain two files if you don't need to.
    BTW, you don't need the cmd[idx++] = "GRID ON;"; statement if you don't need it. It was just part an example on building command strings.
    Eric
    On 02/20/2014 12:23 PM, Leonard Averyt wrote:
    if (board)
       board(B) {
       exit(strjoin(cmd, '\n'));OutputFileName = B.name;/ *<- *********
    always exits the ULP here.*
          B.layers(L) {
            string s = L.name;
    else if (schematic)
  • lenaveryt
    0 lenaveryt over 11 years ago in reply to autodeskguest
    Thanks, I'm really weak with C and C type programming, I'm a ladder guy normally but dabble. I can usually plagiarize and modify code to make what I want, just not good at overall picture etc.
    Thanks everyone, i'll try some of these and get back
