EAGLE User Support (English) netget() translates URLs incorrectly.
  • Replies 22 replies
  • Views 2842 views
I'm trying to use Eagle 5.11 and netget() to get some information from a webpage. The URL contains the string "%2F". When netget() sees that string, it translates it to "%252F". Is there a way to get netget() to leave the characters in a URL alone?
    0 autodeskguest over 12 years ago
    This modification is a syntactic requirement of URLs. Certain characters
    are not legal in a URL and must be escaped. The way this is done is to
    convert them to their ASCII code in HEX preceded by the % symbol.
    Because of this use of %, the % character itself must be escaped, ending
    up as %25.
    Now, armed with that knowledge, you will see that your problem is not
    that you can't put %2F in the URL but that the URL you want contains a
    character which had to be escaped to %2F. The bad news is that there's
    no good reason for that because 2F is the ASCII code of '/' - which is
    the path separator. So either your URL got broken in translation and the
    %2F should become a '/', or it's broken by design in which case you
    probably NEED the behaviour you're complaining about.
    0 Former Member over 12 years ago in reply to autodeskguest
    Thanks for the reply, but you've misunderstood my problem. The URL I'm trying to access has the literal string of "%2F" in it. (I realize this is the escaped code for a '/'. So did the creator of the webpage. That's why he placed the "%2F" in there, and not an actual forward slash.) But I am unable to place a literal of "%2F" into the URL because netget() sees the initial '%' character and escapes it by translating it into "%25", thus giving me a final URL with "%252F" in it.
    Now my way out of this would be to place a '/' into the URL and then have netget() translate that into "%2F". But that doesn't happen because a '/' is the path separator (as you pointed out), so netget() just leaves it as a '/' instead of replacing it with "%2F". (That's a good thing, otherwise netget() would escape all the other slashes that actually are path separators in the URL, too.)
    So my problem is I can't put "%2F" into the URL directly because netget() translates that to "%252F", and I can't put '/' into the URL because netget() looks at that as the path separator and does not translate it at all so it stays as a '/'.
    So, to repeat, I need a way to make netget() stop escaping characters because it's doing it wrong in this specific case.
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to Former Member
    I'm completely going out on a limb here as I have no way to test this, but have you tried putting a backslash in front of the percent sign?  Or what about putting single quotes around the literal '%2F'?
    0 Former Member over 12 years ago in reply to AnalogNotes
    Hi, Doug. Thanks for your suggestions.
    I tried the backslash before with the string "\%2F" and netget translates that into "%5C%252F". So netget() is translating the backslash into "%5C" and the percent into "%25".
    I tried putting single quotes around it like '%2F' inside the URL string. netget() just translates that into '%252F'. So it just ignores the single quotes and still goes inside to translate the percent sign.
    BTW, here's the URL I'm trying to access with netget(): PIC18F14K50-I/SS Microchip Technology | PIC18F14K50-I/SS-ND | DigiKey You'll have to hover over it to see the actual URL. I am able to access this page using Python. I am unable to access the page using netget() with the same URL because of the translation errors.
  • AnalogNotes
    Ugh.  That sucks.  (BTW, hovering didn't give me the escaped literals, but copying and pasting into a new tab showed it to me.)  I just took a look through the EAGLE release notes to see if there were any changes in newer versions, but I didn't find anything.
    I wonder if Jorge has any ideas.  I'll ask him in the morning when I follow up with him about a different email message...
    0 autodeskguest over 12 years ago in reply to Former Member
    Dave Vandenbout wrote on Tue, 25 February 2014 23:18
    webpage.
    That seems to be the real problem here.
    Dave Vandenbout scribbled thus:
    (http://www.digikey.com/product-detail/en/PIC18F14K50-I%2FSS/PIC18F14K50-I%2FSS-ND/1999472)
    Are you sure that the link actually exists ?
    Digikey gives me a "404" Page not found.
    Best Regards:
                          Baron.
  • dukepro
    0 dukepro over 12 years ago in reply to autodeskguest
    The translation to "%2C2F" is indeed correct behavior.  Any ordinary
    browser makes the same translation behind the scenes.
    If you watch the HTTP traffic, among the request headers will be a line
    that starts with "GET", and is followed by the escaped URL.  The reason
    the "%2F" is there in the first place is because the author did not want
    the "/" interpreted as a path separator by the web server - it is
    intended to be part of a search term.  Since the '%' character is used
    as an escape character, it itself had to be translated to %2C.
    Regarding the above link, I clicked it and Digikey brought me right to
    the part without error.  I'm using Thunderbird to read the newsgroup,
    and Firefox as my default browser.
    HTH,
        - Chuck
    0 autodeskguest over 12 years ago in reply to dukepro
    Chuck Huber scribbled thus:
    line
    reason the "%2F" is there in the first place is because the author did
    not want the "/" interpreted as a path separator by the web server -
    it is
    HTH,
        - Chuck
    Thanks Chuck,
    I too am using Firefox.  So it didn't interpret it correctly for me
    either.
    Best Regards:
                          Baron.
    0 autodeskguest over 12 years ago in reply to autodeskguest
    Baron scribbled thus:
    If I cut and paste the link it works properly.  Neither Firefox or
    Chrome find the page if I just click on the link.
    Sorry for the confusion ! Now I understand what is happening.
    Best Regards:
                          Baron.
