EAGLE User Support (English) Rename wires
  • Replies 34 replies
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 5699 views
Rename wires
In an Eagle-shematic (50 pages) I need to change quite a lot of wire names. Select every single and change the name would do the job, but is quite time consuming...
The wires can have diferent names, some examples:
W500/01
W500/02
W500/xx
W501/01
W501/02
W502/01
W600/01
W600/02
W601/01
W700/BN
W700/BU
W135/1.5RD
Now as writen before, a lot of wire names should be changed. For example all W500/xx will be renamed to W512/xx and so on. Can somebody tell me how I can do that a bit more eficient? I tried this one: Renaming parts in Eagle CAD by editing the XML directly
Works quite well for part names, but the wire names are not recognised by this tool. I would have to change the source code (I think I'd be able to do that) and then recompile that, but I have no Idea about C++ and how to compile...
So it would be great if somebody had another simple and working idea how to do that.
Thank you
My configuration:
Eagle 6.5.2 Hobbyist licence
Win 8.1
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to AnalogNotes
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to e14 Contributor
    Well, something I didn't tell you before...  "//" means that anything after this on a line is a comment.  A comment is something only for humans to read.  The computer (EAGLE) ignores everything in the comment.  There is another kind of comment too, a multi-line comment that starts with "/*" and ends with "*/".  For example:
    this is a comment and EAGLE will ignore everything in it
    // this is also a comment, but it only lasts until the end of this one line.
    I'm going to try to use the Github Gist function for the ULP code.  I will do that in the next message...
    0 e14 Contributor over 12 years ago in reply to AnalogNotes
    I tried to put that new code to the old one. Not sure if it could work like that. That is what I tried:
    int minimum = 100;
    int maximum = 199;
    string sheetname;
    string message;
    string oldname;
    string newname;
    string lastpart;
    char c = '/';
    //int number = 100;
    //int position;
    schematic(S){
      S.sheets(SH){
           sprintf(sheetname, "Sheet: %d\n", SH.number);
           message += sheetname;
           SH.nets(N){
                oldname = N.name;
                     int position = strchr(oldname, c);
                     string number = strsub(oldname, 1, position);
                     int test = strtol(number);
                     if ( (test >= minimum) && (test <= maximum) )
                     // in range, do something
                     // position = strchr(oldname, c);
                     // lastpart = strsub(oldname, position);
                     // sprintf(newname, "W%d", number);
                     // newname += lastpart;
                     // number += 1;
                message += "Rename old: ";
                message += oldname;
                message += " to new: ";
                message += newname;
                message += "\n";
    dlgMessageBox(message);
    Now the Message-Box shows me all nets like it did with the old code, but now only the nets matching the test criteria have the "Rename old:" at the beginning...and none of them have a new name after "to new:" somehow hard to explain...It looks like that:
    Sheet: 4
    N$96 to new:
    N$97 to new:
    Rename old: W190/50RD to new:
    Rename old: W191/50BK to new:
    So I think something is wrong, but I have no Idea what.
    As for the regular expressions...thank you for your explanations, but I think I'll put that on hold until I have learned lesson 1 for beginners ;-)
  • AnalogNotes
    Ursicin Caminada wrote:
    The simplest would probably be to look for all wires starting with W1xx (W100 up to W199). I tried to use wildcards like * and ?? (I changed the N.name command to something like W1* or W1?? or W1##) but that doesn't seem to work...I think there is a trivial solution for that?
    One (simple) way is to add this as a test after oldname = N.name;:
    string startpart = "W1";
    int position = strstr(oldname, startpart);
    if (pos >= 0)
      // It starts with W1 and it should be renamed...
    Even beter would be if i could chose a range of numbers to change (only if it doesn't gets to complex!): For example from W100/xxxx up to W299/xxxx, or W100-W199 plus some unnamed wires (N$1 to N$150 for example)
    strxstr? Will that be ULP for beginners lesson 2?
    Yes, strxstr might be a good answer for this because you could write a regular expression that would match the W, then the number, then the slash, or the N$ and the number.
    ^[ \t]+|[ \t]+$...hmm that looks for me like: You have a roof, you spent time repairing it + you spend more time on repairing it and that costs you more $...am I right?
    LOL!  In a regular expression, "^" means the beginning of a line, and "$" means the end of a line.  (They even use "$" as a command in the vim editor to move the cursor to the end of the line.)  The square brackets [] are used for specifying a group, in this case a space and a "\t" which means a tab character.  A regular expression matches anything in the group, so it can be either a space or a tab.  The "+" means one or more of what is right before it.  ("?" is zero or one of the previous thing, and "*" is zero or more of the previous thing.  This is different from the ? and * wildcards.)  The "|" is used to mean the test "or".  So,
    ^[ \t]+ means one or more spaces or tabs at the beginning of a line
    |  or
    [ \t]+$ means one or more spaces at the end of the line
    Simple, yes?  image
    So, to match your wire name, the regular expression would be W\d+ which means a "W" followed by one or more digits.  If you wanted to get all W1xx and W2xx numbers, you could use W[12]\d+ which means one or more digits after either W1 or W2.  You can keep trying to modify the regular expression to test for the range of numbers you want to use, or you might want to just use oldname, get rid of the "W" and use strtol() to convert the digits to a number that you can test with some combination of =, < or >.  It would be easy to put a couple variables at the top of your script instead of trying to modify a regular expression every time:
    int minimum = 100;
    int maximum = 299;
    char c = '/';
    Thanks a lot for your help. So far everything seems to work verry nice. Just one thing: With oldname = N.name; we look for all net names. If possible I'd like to change only a range of names, because for example W300/xx-W900/xx are already in the correct order and should not be changed anymore.
    strxstr? Will that be ULP for beginners lesson 2? image
    ^[ \t]+|[ \t]+$...hmm that looks for me like: You have a roof, you spent time repairing it + you spend more time on repairing it and that costs you more $...am I right? image
    thanks and good night
    0 autodeskguest over 12 years ago in reply to AnalogNotes
    On 04/03/14 20:02, Doug Wellington wrote:
    That's English for "wise man who speaks truth"
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to autodeskguest
    Sorry to continue the off-topic hijack, but that's how these forum things seem to work...  image
    Lorenz wrote:
    There is a nice quote regarding nntp vs. web bases forums:
    Web based forums are like subscribing to 10 different newspapers and
    having to visit 10 different news stands to pickup each one. Email
    list-server groups and USENET are like having all of those newspapers
    delivered to your door every morning.
    I follow about 30-40 news groups and mailing list (using gmane.org as
    mailing list to nntp bridge) regularly.
    That wouldn't be possible using web based forums.
    Using my new client I can skim over the new posts during my morning
    coffee break.
    [curmudgeon]
    Indeed.  I've always hated forums, but it's the way of the world now for most of the topics I seem to be interested in.  I used to, and still do, love listservs (remember Bitnet?) and newsgroups because, as you say, they come to you instead of you having to remember to go to them.  It all seemed so simple back then.  I'm an old MH user too, so I have a *huge* directory structure of messages from both email and nntp.  Of course, for me at least, email isn't the best answer any more, as most people don't edit much, they just pile answers on top of the previous message(s) and most of them are RTF or HTML (in other words, much larger than they need to be).  How many times have you gotten a 90k message that only adds "+1" to all the previous quotes?  image  Forums like this seem to be nicer in that regard, as you have to explicitly click a button to quote the previous message...
    [/curmudgeon]
    CadSoft Guest (aka Lorenz) wrote:
    since when is element14 suppressing the sender of newsgroup post?
    Yeah, this site is a bit wonky, eh?  Do you post from the Stratford
    Digital EagleCentral site or do you post directly via NNTP?  I finally
    gave up on those and use Element14 because I can edit posts.  The down
    side is that the Jive software Element14 uses really just seems to
    suck.  For example, when I click on the "CadSoft Guest" title at the top
    of your message, it is linked to Drew Fustini, and I'm guessing you
    aren't Drew!  As far as I can tell, post edits don't propagate off this
    site, and in general, things are hard to find, which may be more of an
    organization thing than a Jive thing, but it doesn't reflect well on
    either.  There's a webinar about the site in less than an hour, so maybe
    things will clear up a bit...
    I'm posting directly via nntp (since I started using eagle, long long
    before farnell bought cadsoft).
    coffee break.
    Lorenz
  • AnalogNotes
    Yeah, this site is a bit wonky, eh?  Do you post from the Stratford Digital EagleCentral site or do you post directly via NNTP?  I finally gave up on those and use Element14 because I can edit posts.  The down side is that the Jive software Element14 uses really just seems to suck.  For example, when I click on the "CadSoft Guest" title at the top of your message, it is linked to Drew Fustini, and I'm guessing you aren't Drew!  As far as I can tell, post edits don't propagate off this site, and in general, things are hard to find, which may be more of an organization thing than a Jive thing, but it doesn't reflect well on either.  There's a webinar about the site in less than an hour, so maybe things will clear up a bit...
    strxstr?  Do we want to give this poor guy a brain cramp already?
    LOL!!! [...]
    I know 8-)
    I only mentioned it for completeness sake while pointing out that
    there are more possibilities beside strchr and substr
    Thanks.  Yeah, TIMTOWTDI as the Perl guys say...
    The fun thing is, when we come full circle in this discussion, we'll get back to sed, which is actually a great regular expression tool...  image
    also have a look at strxstr, strrchr and strsplit / strjoin  could be
    an alternative
    LOL!!! [...]
    I know 8-)
    Lorenz
