EAGLE User Support (English) Rename wires
  • Replies 34 replies
  • Answers 2 answers
  • Subscribers 189 subscribers
  • Views 5701 views
Rename wires
In an Eagle-shematic (50 pages) I need to change quite a lot of wire names. Select every single and change the name would do the job, but is quite time consuming...
The wires can have diferent names, some examples:
W500/01
W500/02
W500/xx
W501/01
W501/02
W502/01
W600/01
W600/02
W601/01
W700/BN
W700/BU
W135/1.5RD
Now as writen before, a lot of wire names should be changed. For example all W500/xx will be renamed to W512/xx and so on. Can somebody tell me how I can do that a bit more eficient? I tried this one: Renaming parts in Eagle CAD by editing the XML directly
Works quite well for part names, but the wire names are not recognised by this tool. I would have to change the source code (I think I'd be able to do that) and then recompile that, but I have no Idea about C++ and how to compile...
So it would be great if somebody had another simple and working idea how to do that.
Thank you
My configuration:
Eagle 6.5.2 Hobbyist licence
Win 8.1
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to autodeskguest
    CadSoft Guest wrote:
    also have a look at strxstr, strrchr and strsplit / strjoin  could be an alternative
    strxstr?  Do we want to give this poor guy a brain cramp already?  LOL!!!
    Some people, when confronted with a problem, think “I know, I'll use regular expressions.” Now they have two problems.  -Jamie Zawinski*
    For the unknowing/unsuspecting, strxstr() is a very powerful function that uses a thing called a "regular expression" to search for a pattern of characters.  I think the line I quoted from Jamie is hilarious, but I actually *LOVE* regular expressions.  We use them in text processing, for example, building a compiler, which is one of the most advanced things you can do in computer science.  I taught a class on regular expressions and there are entire books devoted to just regular expressions.  image
    *There is a humorous web site devoted to this kind of quote: Two Problems
    EDIT: Here's an example of a regular expression ("regex"):
    ^[ \t]+|[ \t]+$
    quoted from Wikipedia: Regular expression  image
    0 autodeskguest over 12 years ago in reply to AnalogNotes
    Doug Wellington wrote:
    Ursicin Caminada wrote:
    To keep the last part of the name the same, you will have to use the
    string functions of EAGLE.  First, use the strchr() function to find the
    location of the "/" character, then use the strsub() function to extract
    the last part of the string, so etwas:
    an alternative
    Lorenz
    0 e14 Contributor over 12 years ago in reply to AnalogNotes
    Wow, thank you for your huge work and patience.
    Unfortunately it doesn't look like a 5-minute-job to try out image I'll try to go through that step by step, but that has to wait till tomorrow evening. You know, there are such unimportant things like work, sleeping and so on who have to be done as well image
    I really apreciate your help and how you explain it step by step. Like that I have a small chance in understanding what I'm doing... Thank you very much.
    Good night
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to AnalogNotes
    OK, let's look at how we would loop through everything.  In a previous message, I talked about how EAGLE can loop through every sheet of a schematic.  Let's make a test to see how that works.  Create a new ULP or you can use the one we created in the last message and delete everything in it.  Let's start with this code, so copy and paste this into the ULP:
    string sheetname;
    string message;
    schematic(S){
      S.sheets(SH){
        sprintf(sheetname, "Sheet: %d\n", SH.number);
        message += sheetname;
    dlgMessageBox(message);
    Save it and then run it by clicking the ULP button, or you can type "run" and the filename at the command line in the schematic.  (I called my ULP "rename.ulp", so I type "run rename.ulp" and press the enter key.)  You should get a dialog box with a line for every page of the schematic.  EAGLE dialog boxes are not very smart, so it may extend below the bottom of the screen.  Press the escape key or the space bar or click on the close button of the window.
    Now, let's make a list of all the nets on each page of the schematic.  Add in these lines after "message += sheetname;":
    SH.nets(N){
      message += N.name;
      message += " ";
    message += "\n";
    The important things to know here are that we are going through all of the nets on the schematic page, and when we are using each one, it is called "N".  We add the name of the net to the message, then to make it readable, we are adding a space (" ").  After each page, we are adding a new line ("\n") to separate the pages.  So the whole thing should look like:
    string sheetname;
    string message;
    schematic(S){
      S.sheets(SH){
        SH.nets(N){
          message += N.name;
          message += " ";
        message += "\n";
    Save that and run it.  Do you see all of the names of your wires?  If not, we are looking in the wrong place.  Let me know and we will try something else.  If you do see the names that you want to change, then we can proceed.
    Now it's time to add in the name changing code from my last message.  Let's remove the space and newline entries first, then we need to define some more variables:
    string oldname;
    string newname;
    string lastpart;
    char c = '/';
    int number = 100;
    int position;
    Put those lines below the sheetname and message variables.  Now the name changing lines:
    oldname = N.name;
    position = strchr(oldname, c);
    lastpart = strsub(oldname, position);
    sprintf(newname, "W%d", number);
    newname += lastpart;
    number += 1;
    Do you see how I got oldname from the name of the net this time?  The last line here is the magic bit that makes the wire number count up.  Now, let's put in the lines that show what we have done so far in the dialog box.  The whole thing should be:
    string sheetname;
    string message;
    string oldname;
    string newname;
    string lastpart;
    char c = '/';
    int number = 100;
    int position;
    schematic(S){
      S.sheets(SH){
        SH.nets(N){
          oldname = N.name;
          number += 1;
          message += "Rename old: ";
          message += oldname;
          message += " to new: ";
          message += newname;
          message += "\n";
    Run that and see if that looks like what you are trying to accomplish.  In the next message, I'll show you how to generate the script that actually renames everything...
  • AnalogNotes
    0 AnalogNotes over 12 years ago in reply to e14 Contributor
    Win fit? Hmm, not sure how this special command would help me on that right now...for that I use Ctrl+F2...But while I'm writing about; is it just to tell me there are powerfull commands in Eagle?
    Yes, that is just to point out that there are many powerful commands and learning them is a good thing.  Every command can be started from the command line instead of just the mouse...
    I think you understood me a bit wrong. I don't want to rename based on the page number.
    Right now I have the following (just an example):
                               Now                       Should be
    W100/1.5RD  on page 27                  1. W1xx wire on page 01
    W101/1.5RD  on page 32                  2. W1xx wire on page 01
    W102/50RD  on page 01                   3. W1xx wire on page 01
    W103/50BK  on page 45                   1. W1xx wire on page 02
    W104/1.5OR  on page 26                 2. W1xx wire on page 02
    W105/xxxx  on page 14                    1. W1xx wire on page 03
    W149/1.5OR  on page 06                  5. W1xx wire on page 26
    W150/1.5OR  on page 01                  1. W1xx wire on page 27
    Yes, I must be misunderstanding, because it is looking to me like you rename all the wires starting on page one, then going to page two, then three...
    Now the old W100 (on page 27) will be renamed to, W150 (assumed it is the 150iest W1xx wire in the shematic). But the last part of the name should be kept as it was before. The last part of the name is the dimension and the color of the wire, so it should stick to that wire where it is right now. So new we would have:
    W100/1.5OR  on page 01 (because the wire on Page 01 is a 1.5OR)
    W150/1.5RD  on page 27 (because the wire on page 27 is a 1.5RD)
    To keep the last part of the name the same, you will have to use the string functions of EAGLE.  First, use the strchr() function to find the location of the "/" character, then use the strsub() function to extract the last part of the string, so etwas:
    string oldname = "W154/1.5OR";
    char c = '/';
    int position = strchr(oldname, c);
    string lastpart = strsub(oldname, position);
    Now, lastpart should be "/1.5OR".  You can test this by going to the EAGLE control panel, then File->New->ULP and copy this and save it:
    char c = '/';
    dlgMessageBox(lastpart);
    Now open your schematic and then click the ULP button and choose the file you just saved.  the dlgMessageBox command will open a dialog box that should say "/1.5OR" and have an OK button.
    To generate the full new name, use the "sprintf" command, so:
    int number = 100;
    string newname;
    sprintf( newname, "W%d", number);
    Now, newname is "W100".  Then, add the last part to the wire name with "+=", so:
    Test:
    int number = 100;
    char c = '/';
    string newname;
    dlgMessageBox(newname);
    OK, lunch time.  I will post later about how to use this in a loop to process all wires...
    I think my last and your last posts just crossed each other. Anyway.
                               Now                       Should be
    I'll have a look at your sources...and try around a little bit. Happy birthday to your son and have a nice party.
    Btw. we could also write in german ;-) I've just chosen English because I tought the chances to find an Eagle crack would be bigger. Not sure if that would be apreciated if we go on in german. German would be easier, but at the end is also a foreign language for me. So its up to you...
    While writing I just got another idea: I use sed to change all W1xx to W999 (or something else). I would then get W9900, W99901, W99902... Then I would only need a solution how to rename all the W999xx in the script one after the other to W100, W101... Then I get W100xx, W101xx, after that just delete the xx part. Not sure if sed can do that, and if it can how. Probably to simple? I may run in trouble on that wires who start on one page and continue on diferent other pages...?
    Thank you
    Your suggestions so far (with sed) have been just great to change the names of roundabout 60% of the names I'd like to change (W3xx up toW9xx). To change the W1xx names are so to say a new problem.
    You assume right, at the moment I just need to get this problem solved in Eagle. Going deeper into scripting and programming would need time I don't really have right now...
    Win fit? Hmm, not sure how this special command would help me on that right now...for that I use Ctrl+F2...But while I'm writing about; is it just to tell me there are powerfull commands in Eagle? If so, I know that, but I have no Idea how to use them correctly to solve my problem. This is my first project in Eagle and I am learning by doing. That's also why I have to rename a lot. It startet small and back then the net names where not really an issue, but as things grew (up to 50 pages right now) I got more and more messed up on that...
    I think the rename command would be my best friend, but to solve my problem in a reasonable amount of time and manual work, that one should probably bring some other friends along with. As for using scripts in Eagle, I played a little bit around with the scr and ulp functions in Eagle, but I have not really a clue how to use them correctly to solve my problem. Said that, i'd really apreciate if you could give me some advice how to do that.
    By the way, if that script could also reorder the terminals who are aranged "chaotic" all over the shematic would be nice. I promess, this is the last "new" labelling issue I'll ask about ;-)
    The terminals are labelled 11X01, 11X02..., 12X01, 12X02..., 14X01...
    11X, 12X 14X should never change, the numbers after the X would be nice if they start on page one left  with 01 and then continue on. Mainly the same problem as with the W1xx but no numbers/letters at the end who schouldn't be changed.
    Thank you very much
  • AnalogNotes
    Now interestingly enough, The EAGLE scripting language doesn't have any control structures.  That means there is no way to test things, or repeat things, other than to duplicate a line x number of times.  EAGLE scripts are just brute-force lists of commands to run.
    So, for whatever reason, the Cadsoft folks decided to leave the scripting alone and add a different programming language to create scripts.  This is called "User Language" and you create User Language Programs (ULPs).  The interesting thing about ULPs is that they don't get to change things while they run, they have to generate EAGLE scripts that you run after the ULP is complete.  In some ways, this is a very Unix-like thing to do.  And I'm part German, (born in Frankfurt actually), so I have the in-group privilege to say it's a very German thing too!  LOL
    SIDE NOTE: It would be amazingly cool if Cadsoft made all of the EAGLE commands available as library functions that could be called by other languages.  Personally, I'd love it if I could start up a Python program, import an EAGLE library and directly manipulate a schematic or board!  image
    So, anyway, User Language is very powerful, it knows about the structures in EAGLE files.  This saves *lots* of time!  You can write a ULP that works with the schematic, the board, a library, or parts of any of them.
    I'm not sure I know *exactly* what you're trying to do, but my first interpretation is that you want to renumber wires based upon which page of the schematic they are on.  So, in a ULP, we would start by using the schematic, then looping through each page of the schematic.  The code to do that would be:
    schematic(S){
      S.sheets(SH){
         // do something here
    The first line says we're going to work with the schematic and call it "S".  The next line says, take S, and go through each sheet in it one at a time and call it "SH" while we're using it.  I took a quick look at the EAGLE help, and I found that you can go through each wire of the sheet by adding:
    schematic(S){
      S.sheets(SH){
        SH.wires(W){
          // do something with each wire here
    But the problem seems to be that the name of each wire is not listed in the data members of the UL_WIRE structure.  I'm guessing we'll have to loop through something different, like nets() maybe:
    schematic(S){
      S.sheets(SH){
        SH.nets(N){
          // do something with each net here
    This illustrates the toughest part of writing a ULP, figuring out the parent-child relationships of all the structures.  Once you get the structure correct, then at the "do something" point, we output the command that does the actual rename.
    I apologize, but I must depart for the day, my son turned 19 today and we have a party to prepare for.  I hope I've given you some hints as to how you might proceed.  I'm not sure, but I think I'd probably look at looping through segments() and labels() next.  Everything is documented in EAGLE help.  If you want to directly access the file with your web browser the way I do, open the file eagle_en.htm in the bin directory of your EAGLE installation, or you can get to the help files on my web site at http://analognotes.com/eagle/helpfiles/
    If you learn from reading other people's code, go to the Cadsoft ULP download site and search for "renumber"...
  • AnalogNotes
    My suggestions so far have been based on treating the schematic file as one big stream of text.  (That is what Unix was originally designed for, to process streams of text.). When we need to start thinking about the structures in a file, we need to use a different type of tool.
    There are two categories of solution that come to mind.  We can either try to use the tools that are built in to EAGLE, or we can use one of those scripting languages I mentioned.  It's a trade off between specific knowledge and general applicability.  Are you more interested in learning more about EAGLE or learning how to write scripts that can apply to other programming problems?
    Let's assume that you just want to get this problem solved, so we'll use available tools for this task and not reinvent anything.  EAGLE has a command prompt right there on the screen.  You can type commands instead of selecting them with a mouse.  Just for grins, when you have your schematic open, type "win fit" and press the enter key.  Just like a sed file, or an operating system batch file, you can put a series of these commands into an EAGLE script file and run it.  If you use a particular script a lot, you can assign it to a key or add it to a menu.  This is what makes EAGLE so appealing to an old Unix guy like me!
    More in a bit.  I can't stand using this iPad to type...
    small thing, big consequences...thank you very much, I missed that one. Now everything works perfectly. In combination with the script file it is very powerfull.
    For a more complex rename I'm now looking for a solution as well. Lets asume we have the following net names:
    W100/1.5RD
    W101/1.5RD
    W102/50RD
    W103/50BK
    W104/1.5OR
    W105/xxxx
    W150/1.5RD
    W151/1.5OR
    These names are in no order somewhere in the schematic. Is it possible to sort these so that the first W1xx is on page 1 and so on. Important; the numbers and letters after the slash should not be changed. So for example if W150/1.5RD is changed to W103 it should still have the /1.5RD at the end. The "old" W103 may then become W104/50BK, W104 is changed to W105/1.5OR and so on...Hope you understand what I'd like to do.
    Thank you very much for the great help.
