EAGLE User Support (English) Export a schematics into LTSPICE file
  • Views 3753 views
I made a schematics with Eagle 6.5.0 but when I try to export it with the LTCSpice button, it writes "Different quantity of SpiceOrder and PINs in symbol C-EU of part C1 (C-EUC0805K). Please check symbol!".
I have absolutely no idea of what this mean, in spite of my searches on the internet.
When I click on OK, it is written "OPEN 'C:/Program Files (x86)/EAGLE-6.5.0/lbr/rcl.lbr'; EDIT C-EU.DEV;RUN spiceorder.ULP"
What is a SpiceOrder please ? And can anyone help me to export my file please ?
Thanks for any kind of help image
Antoine
    0 autodeskguest over 12 years ago in reply to e14 Contributor
    On 3/7/2014 6:09 AM, Antoine POULET wrote:
    Thank you for your help, I did this, but it did not change anything, I
    still have the same problem. Moreover this manipulation seems a little
    bit dangerous for my computer, don't you think ? It makes me lose a
    protection, I think.
    That's one way to look at it, but so far that "feature" has caused
    nothing but headaches for many programs. I'm suprised it didn't work.
    When exporting to LTSpice did you remember to click Export Setup under
    the LTSpice icon in the schematic? This establishes your environment.
    Those files are the manufacturer provided SPICE models for the
    component
    I created. Whenever you're going to use a manufacturer's SPICE model
    for
    a part you created you'll have either a .MOD or a .sub file that
    describes how the part works to LTSpice.
    Ok, do you know where I can find these files ? Does it means that I
    cannot use a component if I don't have it's SPICE model and .MOD .sub
    files downloaded before ? Or is it something I should create by myself ?
    The files are usually provided by the part manufacturer. LTSpice has
    certain standard models which you can use if you're making a passive or
    something like that. In some cases you may want to make your own models
    but most of the time you'll use the ones provided by the manufacturer.
    hth,
    Jorge Garcia
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    You're getting bit by the UAC virtualization of Windows 7(or Vista or
    8). It sounds like Windows is not allowing EAGLE to write to the LTSpice
    installation directory.
    Here's one way around it:
    How to Bypass UAC Virtualization
    Windows Control Panel > User Accounts > Change User Account Control Settings
    Move the slider from the default of the third click down to the bottom
    level "Never notify..." and reboot.
    Thank you for your help, I did this, but it did not change anything, I still have the same problem. Moreover this manipulation seems a little bit dangerous for my computer, don't you think ? It makes me lose a protection, I think.
    Those files are the manufacturer provided SPICE models for the component
    I created. Whenever you're going to use a manufacturer's SPICE model for
    Ok, do you know where I can find these files ? Does it means that I cannot use a component if I don't have it's SPICE model and .MOD .sub files downloaded before ? Or is it something I should create by myself ?
    Best regards,
    Antoine
    On 3/4/2014 11:14 AM, Antoine POULET wrote:
    Thank you for your anwer Jorge,
    After watching the video, I found that I had to modify the components. I
    changed my capa with LTSPICE capa, and I set SpiceOrders for each pin of
    each component. But when I try to export the device of a photodiode
    BPW32 into LTSPICE component, there is an error : "Can't build:
    C:/Program files (x86)/LTspiceIV/lib/sym/eagle/opto-trans-siemens "
    And if I try to export my schematics, I have the same error than in my
    first post but for the photodiode BPW32, even though this photodiode
    have his SpiceOrder already set.
    In the video you show some .MOD and .sub files, I don't have these
    files, you had it on his Desktop but I don't know what it represent. Is
    it something you have created ?
    Sorry if I ask stupid questions but I'm a newbie on this subject.
    And sorry for my English mistakes, I'm French image
    The only stupid question is the one you don't ask. We're here to help,
    so feel free to ask any and all questions.
    hth,
    Jorge Garcia
    Cadsoft Computer
    Best regards,
    Antoine
    http://www.element14.com/community/message/105418
  • papas
    0 papas over 12 years ago in reply to e14 Contributor
    LTSpice
    Lost time
    Very amateur work, for the current season (ancient) real time circuit simulator
    See here
    http://www.youtube.com/watch?v=lyADW32wi10
    And hare
    http://www.youtube.com/watch?v=J1_Dn8ip5Xs
    Do not forget that we cover year 2014 And no in 1990
    After watching the video, I found that I had to modify the components. I changed my capa with LTSPICE capa, and I set SpiceOrders for each pin of each component. But when I try to export the device of a photodiode BPW32 into LTSPICE component, there is an error : "Can't build: C:/Program files (x86)/LTspiceIV/lib/sym/eagle/opto-trans-siemens "
    And if I try to export my schematics, I have the same error than in my first post but for the photodiode BPW32, even though this photodiode have his SpiceOrder already set.
    In the video you show some .MOD and .sub files, I don't have these files, you had it on his Desktop but I don't know what it represent. Is it something you have created ?
    Best regards,
    Antoine
    Hi Antoine,
    I hope you're doing well. Check out the "Simulate with EAGLE" video on
    Youtube. It's a 40 minute tutorial on how to use your own models with
    EAGLE and LTSpice.
    It will clear what SpiceOrder is and how to define it in your components.
    Best Regards,
    Jorge Garcia
