EAGLE User Support (English) Where are the files?
  • Subscribers 179 subscribers
  • Views 1010 views
sailmike1
sailmike1 over 11 years ago
I just made some changes to an old PCB and opened CAM to create a new set of gerber files. Those files appear to have been created, but they aren't showing up in the project folder. One of the following pictures shows the files in the control panel window. I followed the path indicated at the bottom of the screen, but they just aren't there. What's going on? I'm running Eagle 6.4 standard edition on Windows 8.1.
Mike
Fullscreen contentimage_30353.html Download
<html><head><title>Jive SBS</title></head>
<body><font face="arial,helvetica,sans-serif">
<b>Error</b><br><font size="-1">
An general error occurred while processing your request.
</font></font></body></html>
Fullscreen contentimage_30354.html Download
    Am 05.03.2014 09:40, schrieb Michael Levin:
    Mike
    http://www.element14.com/community/message/105496
    Perhaps the usual win problem...
    Check under users (your name)...
    Joern Paschedag
  • sailmike1
    0 sailmike1 over 11 years ago in reply to autodeskguest
    Checked that, no luck.
  • AnalogNotes
    0 AnalogNotes over 11 years ago in reply to sailmike1
    Just a suggestion for the future, but I think you should make an EAGLE directory under your documents directory and change the directory setting in the EAGLE control panel to use it instead of the Program Files area...
    0 autodeskguest over 11 years ago in reply to AnalogNotes
    If the path you thought your files were in was under the "Program Data" or
    "Program Files" path, then check the "virtual store" under your account -
    windows has this "feature" where it will put things there and let you think
    you put them in the install directory.  BUT it doesn't tell you it did that
    and you can spend days trying to figure out why some things can find them,
    but you can't or the latest license file you put in the install directory
    is not working (an old version was in the "virtual store" and it was
    looking there first.  At least under windows 7, the virtual store will be
    "C:\Users\mikey\AppData\Local\VirtualStore" (obviously change the account
    name to yours).
    mikey (having been bitten by this one recently with another program ... )
  • sailmike1
    Mikey, I had the computer do a search for the files and found them in the folder you mentioned. Thanks!
    From the control panel in Eagle I changed the projects directory. I hope this solves the problem. I hope I don't have to do this for every project.
    Fullscreen contentimage_176330.html Download
    0 autodeskguest over 11 years ago in reply to sailmike1
    Glad you found them - that "virtual store" has tripped up quite a few
    people.  Where you can get bitten (I think this is where it got me) was
    when I tried to drag some license files from an email to a "protected"
    folder.  Windows apparently handles files from an email differently than
    files you have on your desktop for example even if you have admin rights
    the whole time.  The bottom line is to recognize that apps that try to
    write to the protected folders (many older apps store ini files and other
    such things in their install folder) end up with stuff in the "virtual
    store" which can cause interesting things down the road.  I first read
    about it in this forum if I remember correctly where someone had some
    library files that Eagle could see, but he could not see them with windows
    explorer looking in the directory they said they were in (they were
    actually hidden down in the "virtual store")
    mikey
