EAGLE User Support (English) Metric CAM (excellon/gerber) files
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 2171 views
I am designing a metric board, can I generate cam files
that are also metric, if so how ? It seems that the excellon and gerb274x
cam files generate inch-based outputs. Do board houses
even accept metric cam files ?
If conversion to inches is not necessary, I would
like to avoid it, for all the obvious reasons.
Andy
    autodeskguest over 16 years ago in reply to autodeskguest
    StigOE wrote on Wed, 03 March 2010 02:41
    Maybe he read Olimex's FAQ which says:
    Quote:
    Q: I designed my board in Inch (mm) units, in which units should I
    export my Gerbers?
    A: Always export your gerbers in the units you designed board to
    prevent rounding errors in your Gerber generation due to the unit
    conversion.
    That is both silly and misleading.  Olimex is hardly the board house to
    listen to.  They are the only board house I've ever encountered that wanted
    files different from what every other board house was happy with.  (In
    addition they had a uppity attitude about it and tried to make it look like
    I was a criminal for even asking for a quote.  Fortunately there are better
    board houses out there, so there's no need to put up with that sort of
    crap.  I use Gold Phoenix for most of my prototypes, for example.)
    In addition to that, I thought I read somewhere but can't find now that
    Eagle stores coordinates internally as integers of some very small unit.
    Your board isn't inherently in mm or inches anyway.  I think the small unit
    was deliberately chosen so that integer multiples would get to both a small
    round fraction of a mil and a mm.  Even if not, any roundoff error will be
    so small as to be irrelevant since the CAM processor write extra digits for
    this reason.
    Maybe this doc is of relevance to your Q
    http://www.artwork.com/gerber/274x/rs274xrevd_e.pdf
    Table 1, page 9 shows there are codes to select inch or mm units. Eagle's
    CAM processor does inch all the time afaik.
    Olin wrote on Tue, 02 March 2010 22:07
    There is no "conversion" to worry about since how you got to the
    measurements has nothing to do with how they are written to CAM files.
    And no, your objection is not obvious at all.  I would leave the defaults
    alone.  Board houses know how to interpret these files.  I wouldn't send
    a board house a metric Gerber file unless they specifically told me they
    can handle it.  No board house is going to misinterpret a inch file.  I'd
    be more worried that their process assumes inch files and therefore
    misinterpret metric ones.
    export my Gerbers?
    conversion.
    which would make it obvious to not want to make gerbers in inch when the
    board is made in mm. But, what do I know... image
    Stig
    Andy Warner wrote on Mon, 05 January 2009 12:37
    I am designing a metric board, can I generate cam files that are also
    metric, if so how ?
    What units you used to size the board and define the packages on that board
    have nothing to do with how the resulting information is written to Gerber
    files.  Most boards require a mix of units for various parts anyway.
    Quote:
    It seems that the excellon and gerb274x cam files generate inch-based
    outputs. Do board houses even accept metric cam files ?
    If conversion to inches is not necessary, I would like to avoid it, for
    measurements has nothing to do with how they are written to CAM files.  And
    alone.  Board houses know how to interpret these files.  I wouldn't send a
    board house a metric Gerber file unless they specifically told me they can
    handle it.  No board house is going to misinterpret a inch file.  I'd be
    Keep in mind that inside Eagle it's really neither inches nor mm.  If I
    remember right, they use integers of some very small unit.  But all that
    doesn't matter.  The computer will convert.  Computers are good at that
    sort of thing.
  • Richard_H
    Richard_H over 17 years ago
    Andy Warner schrieb:
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:gk727q$ean$1@cheetah.cadsoft.de...
    ResY     = 25400
    This means you male 25400 steps per inch. Which results in a
    resolution of 1/100 mm.
    I think I have edited eagle.def correctly now to include mm 3.3
    excellon and gerber devices. Do I need anything funky to the .cam
    files ? They seem peppered with inch-based detail too.
    The gerbers look OK in my gerber viewer, when I just copy
    the excellon and gerb274x .cam files and reference the corresponding
    MM33 output device.
    You don't have to change anything in the CAM files. Simply use
    the Devices you have changed.
    Richard Hammerl
    autodeskguest over 17 years ago in reply to Richard_H
    ResY     = 25400
    MM33 output device.
  • Richard_H
    news:gk4fq1$tqm$1@cheetah.cadsoft.de...
    It's possible to change the definition of the Gerber device in the
    eagle.def file or even add further devices.
    For example, Gerber in MM, data format 3.3:
    Thanks, I'll try that tomorrow - much appreciated.
    Here's what I had hacked together (untested) for a metric excellon
    device to generate .drd files:
    Type     = DrillStation
    Long     = "Excellon drill station"
    Init     = "%%\nM48\nM72\n"
    Reset    = "M30\n"
    ResX     = 1000
    ResY     = 1000
    ;Rack     = ""
    DrillSize  = "%sC%0.4f\n"        ; (Tool code, tool size)
    AutoDrill  = "T%02d"             ; (Tool number)
    FirstDrill = 1
    BeginData  = "%%\n"
    Units    = mm
    Select   = "%s\n"                ; (Drill code)
    Drill    = "X%1.0fY%1.0f\n"      ; (x, y)
    Info     = "Drill File Info:\n"\
              "\n"\
              " Data Mode         : Absolute\n"\
              " Units             : 1/1000 mm\n"\
              "\n"
    Is that adequate, or do you have a better suggestion ?
    I'm looking forward to banishing inches from my process.
    Andy
    You still have to change the resolution. Set
    ResX     = 1000
    ResY     = 1000
    to
    ResX     = 25400
    ResY     = 25400
    HTH
    Richard Hammerl
    Type     = DrillStation
    Reset    = "M30\n"
    ResX     = 1000
    ResY     = 1000
    ;Rack     = ""
    FirstDrill = 1
    BeginData  = "%%\n"
    Units    = mm
               "\n"\
               "\n"
    Andy
  • Richard_H
    Andy
    Type     = PhotoPlotter
    Long     = "Gerber photoplotter"
    Init     = "G01\nX000000Y000000D02\n"
    Reset    = "X000000Y000000D02\nM02\n"
    ResX     = 25400
    ResY     = 25400
    ;Wheel    = ""
    Move     = "X%0.6dY%0.6dD02*\n"    ; (x, y)
    Draw     = "X%0.6dY%0.6dD01*\n"    ; (x, y)
    Flash    = "X%0.6dY%0.6dD03*\n"    ; (x, y)
    Aperture = "%s*\n"               ; (Aperture code)
    Units    = mm
    Decimals = 4
    Info     = "Plotfile Info:\n"\
               "\n"\
               " Coordinate Format : 3.3\n"\
               " Coordinate Units  : mm\n"\
               " Zero Suppression  : None\n"\
               " End Of Block      : *\n"\
               "\n"
    @GERBER_MM_33
    Long          = "Gerber photoplotter with automatic aperture wheel
    generation"
    Wheel         = "" ; avoids message!
    AutoAperture  = "D%d" ; (Aperture number)
    FirstAperture = 10
    Decimals      = 4
    Units         = mm
    @GERBERAUTO_MM_33
    Long          = "Gerber photoplotter with RS-274-X aperture generation"
    Units         = mm
    Init          = "G75*\n"           \ allow positive and negative coordinates
                    "G71*\n"           \ units are mm
                    "%%OFA0B0*%%\n"    \ horizonal and vertical OFfset is 0
                    "%%FSLAX33Y33*%%\n"\ Format Statement is Absolute (I for
    incremental) 3.3
                    "%%IPPOS*%%\n"     \ Image Polarity is POSitive (NEG for
    negative)
                    "%%LPD*%%\n"       \ Layer Polarity Dark (C for clear on
    negative planes)
                    "%%AMOC8\n5,1,8,0,0,1.08239X$1,22.5\n"\ Octagons are
    emulated with a circle (using 8 vertices)
                    "%%\n"            ; and therefore the diameter must be
    enlarged with '1 / cos(pi / 8)'
    Reset         = "M02*\n"
    Circle        = "%%AD%sC,%6.3f*%%\n"        ; (code, diameter)
    Rectangle     = "%%AD%sR,%6.3fX%6.3f*%%\n"  ; (code, dx, dy)
    Oval          = "%%AD%sO,%6.3fX%6.3f*%%\n"  ; (code, dx, dy)
    ; According to the RS-274-X specs there is an aperture macro
    ; primitive that allows us to specify an octagon (i.e. a polygon with
    ; 8 vertices). As some Gerber viewers seem to have problems with that,
    ; we would have to use a round shape for that.
    ; If your Gerber processor cannot handle the polygon primitive you may
    ; uncomment the following line and comment out the line after it:
    ;Octagon       = "%%AD%sC,%6.3f*%%\n"   ; (code, diameter) (looks like
    there is no octagon, so we take a circle)
    Octagon       = "%%AD%sOC8,%6.3f*%%\n" ; (code, diameter)
    Annulus       = "%%AMAN%s\n1,1,%6.3f,0,0\n1,0,%6.3f,0,0*\n"\
                    "%%\n"\
                    "%%AD%sAN%s*%%\n" ; (code, diameter, inner diameter,
    code, code)
    Thermal       = "%%AMTH%sX\n1,1,%6.3f,0,0\n1,0,%6.3f,0,0*\n"\
                    "21,0,%6.3f,%6.3f,0,0,45\n21,0,%6.3f,%6.3f,0,0,135\n"\
                    "%%\n"\
                    "%%AD%sTH%sX*%%\n"; (code, diameter, inner diameter,
    diameter + 2mil, gap, diameter + 2mil, gap, code, code)
    Richard Hammerl
