EAGLE User Support (English) Problem with Eagle 6.5
  • Subscribers 179 subscribers
  • Views 438 views
  • board
Sir,
    I am using Eagle 6.5 and I have created PCB design in editor. I am facing the problem of the pitch dimensions of IC packages. When I print the design on paper using PRINT command for making PDF, the pitch(distance between the pins of IC package) don't match with the original IC. For example, If I use DIL 18 pin package then ideally after printing, it should match with all DIL but its not matching and I cannot place the IC on board. I lost 2 boards fabricated in due to this error. Any help would be appreciated.
  • Richard_H
    0 Richard_H over 11 years ago
    how did you produce the manufacturing data? If you print the layout (with the PRINT command) how are the settings for "scale" and "Limit"? Are you sure that you  print 1:1 ?
    Richard
    0 Former Member over 11 years ago in reply to Richard_H
    Its 1:1 scale is 1 and limit is 0
  • Richard_H
    0 Richard_H over 11 years ago in reply to Former Member
    could it be a matter of the printer? Do you know that you can calibrate  the printer's output in x and y direction in the PRINT dialogue as well?
    Best regards,
    Richard
    Maybe. But I don't know the calibration. Could you please tell me for printing 1:1?
    0 autodeskguest over 11 years ago in reply to Former Member
    printing 1:1?
    No, we can't, because that's the point. The calibration is provided to
    account for the printer not reproducing exactly to scale. This is an
    error in the printer; one that is expected but not known in advance. It
    could be manufacturing tolerances or paper shrinkage or a firmware quirk
    or even down to the drivers on your PC.
    The way you set the calibration is by measurement.
    Create a blank PCB with just a pair of specific length marked-off axes
    in the dimension layer. 10cm long would be reasonable.
    Print this at 1:1 with calibrations of 1.0 in both axes
    Using a ruler, measure accurately the actual length of the 10cm axes
    Calculate the calibration factors by dividing:
                       Designed length of axis
        Calibration = -
                       Measured length of axis
    Print again with these calibrations and check that you now have the
    correct printed lengths.
