EAGLE User Support (English) Change pad shpe to rectangular
  • Subscribers 180 subscribers
  • Views 254 views
ramdas.adav1989
ramdas.adav1989 over 11 years ago
How can I change the shape of pad of first pin of IC to rectangular long shape?
There are only options of square, hexagon and round.
    I ended up adding four .05 x .025 Smd pads to the dip packages I am using, 2ea on the top layer and 2ea on the bottom layer, leaving the original pin #1 pad in place.  Remove the cream setting on the Smd pads.
    I circled all five pads and copied them, went to the other dip packages in the library, pasted the copied pads over pin #1 and then deleted one of the pin #1 pads then saved that package.
    I hope this helps.
