EAGLE User Support (English) How can I measure diameter?
  • Subscribers 189 subscribers
  • Views 1009 views
Hi. Here is some questions of Eagle CAD 6.4.
I've tried to measure diameter of a small circle and length of other small objects using Dimension button, but failed.
It shows the arrow reversed and the arrow doesn't grab any points of the small objects well although I used ALT button.
I made the size of letter on the arrow small but the arrow is still too big to measure a small objects.
What should I do?
I really appreciate your effort and time.
Steve.
    0 e14 Contributor over 12 years ago in reply to AnalogNotes
    Thank you , Doug.
    This is not what I want to do.  I already know that method.
    I'm curious why Eagle CAD company make Dimension tool.
    If I measure as you said, what is the Dimension tool for?
  • AnalogNotes
    0 AnalogNotes over 12 years ago
    The dimension tool is really for making things for humans to read.  If you want to measure from one point to another, use the MARK command, click on one point, then move the mouse cursor to another point and you'll see the readout change.  You may have to change the grid to a finer size to get the accuracy you want...
