EAGLE User Support (English) How to copy package within the same library?
  • Subscribers 178 subscribers
  • Views 1601 views
embeddedbob
embeddedbob over 11 years ago
I find hundreds of pages that tell how to copy a device from one library to another, but I've created a package in my library that I'd like to copy to another name within the same library and then modify it. How do I use the copy command to do this?  Everything I've tried has failed.
Bob
    I find
    quote]
    HI Bob
    Display the package you wish to replicate. Note the grid
    Type into the command line
    GROUP ALL
    Select COPY and copy the group
    Then commence the creation of a new package and give it the new name.
    Set the grid the same as before
    Paste the copied package into the new package
    It would pay to confirm that the pads are located as per the original
    Save
    HTH
    Warren
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Warren Brayshaw wrote:
    I find
    quote]
    HI Bob
    at this point i'd add
      display all
    GROUP ALL
    Save
    and back to the previous layer selection
      display last
    or do everything on the command line:
      edit sourcePackageName
      display all
      group all
      copy (>0 0)
      edit targetPackageName
      paste (0 0)
      display last
    or put the following in an ULP
      exit("edit " + argv[1] + "; display all; group all; copy (>0 0);"
           "edit " + argv[2] + "; paste (0 0); display last;");
    and run it with
      run uplName sourcePackageName targetPackageName
    Lorenz
  • embeddedbob
    0 embeddedbob over 11 years ago in reply to autodeskguest
    Bingo!  That solved the problem and saved me hours of time!  Thanks Warren for your help.
    Bob
