EAGLE User Support (English) Search (find) command does not change value
  • Subscribers 178 subscribers
  • Views 245 views
  • search
  • find
  • value
  • change
masoudh
masoudh over 11 years ago
I'm using ver 6.5.0 and trying to change values of a bunch of components at once. If I go to Tools>Search... to setup the search or even if I do for example: "run find 100nF CH 0.1uF *" I cannot get it to change the values. It searches and finds and displays all the correct values but does not change them. What am I doing wrong?
Thanks.
    I'm using ver
    The method Tools>Search works. You need to ensure you but a number in the
    counts field that defaults to '0'. Also ensure you type the value as it is
    in the editor.
    I could not get the RUN method to work. I suspect it needs a fix.
    HTH
    Warren
  • masoudh
    0 masoudh over 11 years ago in reply to autodeskguest
    Tools>Search is not working for me either. It does exactly the same as "run find". They both find all the instances and display them in a rapid succession but do not change the values! image
