EAGLE User Support (English) Unknown identifier 'sleep' while running felicitas_pcbsim.ulp
  • Answers 2 answers
  • Subscribers 179 subscribers
  • Views 826 views
  • ulp
  • pcbsim
kikoun
kikoun over 11 years ago
I tried to run the filicitas_pcbsim.ulp but I get an error "Unknown identifier 'sleep'". I didn't edit this ulp, I just download it from www.cadsoftusa.com.
So I download the user language documentation of eagle 6.5.0 and I search for sleep. Of course there is no 'sleep' command ! image
I guess I must change this sleep command by something else. But I don't know what.
Any idea ?
Guillaume Barrey.
PS: I run eagle 6.5.0 professional, on a Linux PC (SUSE 13.1).
    there is currently no stable EAGLE version supporting 'sleep'. You can
    either wait for V6.6 or alternatively try the latest beta ('sleep' has
    been added in 6.5.2).
    Rene
    0 autodeskguest over 11 years ago in reply to autodeskguest
    rk wrote on Thu, 08 May 2014 15:08
    Then the proper way to do that is to check the version of EAGLE that is
    running and refuse to run if the version isn't high enough.  Then the user
    knows that the particular ULP isn't supported without upgrading.  You can
    even add a dialog that indicates the minimum version to help out.
    Not sure who the author of the ULP is, but this should be added if you
    don't want 1000 questions about the same thing.  And it's generally a good
    practice to use in any ULP.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    Take advantage of v7 License Promotion right now at
    http://www.eaglecentral.ca
  • kikoun
    0 kikoun over 11 years ago in reply to autodeskguest
    I can agree more... especially when the ulp is presented on the home page of cadsoft website image...
    and, It should be presented as a "future feature" since there is no eagle stable version that support it !
    G. Barrey
    Am 08.05.2014 22:33, schrieb James Morrison:
    There is no need for an ULP to check that, as we have the #require
    directive. The author actually added that directive, but the value has
    been set to the wrong value.
    They officially released an ULP without having a stable version being
    able to run that ULP. This also does not look as being good practice.
    Rene
    rk wrote on Thu, 08 May 2014 17:14
    that is
    the user
    You can
    That's the facility I meant, just didn't look it up.  I forget it if tells
    you the message by default or if you have to do that with your own dialog.
    But the ULP shouldn't try to run if it knows it can't due to version
    issues.
    you
    a good
    True.  If you set the require to 6.5_2 then it will work when the major
    release comes around (in theory) but would give an error on the current
    stable release.  That would be better.
    I understand you might want to get it out there but having it not run on
    the current stable version isn't great.
    James.
    On 9/05/2014 7:08 a.m., René König wrote:
    Rene
    Or alternately insert your own sleep() function into the ULP.
    Place the following into the ULP at around line 200 after the line:
    /* ################## Functions ####################### */
    /* ###########Copy the lines below########### */
    void sleep(int secs)
         int start     = timems();
         while (timems() - start  < secs *1000);
    /* ########### Copy the lines above ######### */
