EAGLE User Support (English) I can't install eagle-win-6.5.0.exe; error is "not a valid win32 application"
  • Subscribers 179 subscribers
  • Views 385 views
  • eagle
  • install
  • installation
  • cadsoft
Hey there all -- I'm trying to install eagle-win-6.5.0.exe on a Windows 7 Professional x64 workstation.
I get the error message "c:\install\eagle-win-6.5.0.exe is not a valid win32 application."
I've downloaded the installer several times, using different web browsers (IE, firefox, chrome), with the same result.
I've just tried downloading and installing eagle-win-6.5.0.exe on a different computer, with the same error message.
What's going on?
I'm running Nod32 antivirus on the latter PC, and when I try to scan the install file, Nod32 notes --
"C:\install\eagle-win-6.5.0.exe » ZIP » lbr/con-amp.lbr - archive damaged - the file could not be extracted."
So it's ?possible? the install file I'm downloaded is damaged in some way.
Any ideas, folks?  I'm currently stumped.
Thanks for any suggestions.
  • AnalogNotes
    0 AnalogNotes over 11 years ago
    If you right click on the file and select properties, what is the file size?  It should be a bit larger than 44MB.  If it's smaller than that, the file wasn't completely transferred...
