EAGLE User Support (English) Change transparency of top layer
  • Subscribers 178 subscribers
  • Views 1007 views
  • eagle
  • transparency
  • layer
paulr54
paulr54 over 11 years ago
I have an Eagle board file in which the top (red) copper layer is almost opaque, and the bottom (blue) layer barely visible behind it. I assume this can be adjusted as all my other files are fine, but I can't find the option for it. Can anyone help?
Thanks.
  • paulr54
    0 paulr54 over 11 years ago
    No suggestions? Here are some samples of how files display:
    Normal:
    https://www.dropbox.com/s/pidmft86olovb3x/Clipboard01.png
    (blue tracks show through red layer)
    Too opaque:
    https://www.dropbox.com/s/btcfrq6phhnx8yy/Clipboard02.png
    (blue tracks almost invisible through red layer)
    I suspect the bad board has more layers than the other. Turning  off the
    internal layers should help.
    It appears you have alpha blending turned on. It may help if you turn
    that off.
    Options > Set > Colors -  Remove the tick from 'Use alpha blending'
    HTH
    Warren
    0 autodeskguest over 11 years ago in reply to autodeskguest
    warrenbrayshaw wrote on Wed, 21 May 2014 05:11
    almost
    assume
    find
    the
    that off.
    If it's a board that came from someone else, it is possible the colour
    palette settings are messed up.  The colour palette indices are stored in
    the EAGLE file but the palette itself is stored with your EAGLE
    installation so it is possible that you're using the original designer's
    indices into his palette but actually using your palette.  This can make
    things really bad.
    To clean it up, run the following scripts:
    script defaultcolors.scr
    script mylayers.scr
    By doing that you'll reset all the colours and layer information to what it
    was out of the box.
    The only problem with that is that it sets the background of the PCB to
    "white" which I don't like.  I take these, copy to my own script directory,
    and then edit them slightly by adding this to the end of defaultcolors.scr
    BRD:
    set palette black;
    window;
    SCH:
    set palette white;
    window;
    DEV:
    set palette white;
    window;
    SYM:
    set palette white;
    window;
    Then I create a new script called "reset-colors.scr" which has the two
    script commands above and then I can reset the colors with one command
    script reset-colors.scr
    It seems like a lot of work for someone to do to simply reset the colours
    to out of the box condition.  I need to do this ALL THE TIME because I have
    a different palette then everyone else.  Just another reason why CadSoft
    needs to put some effort into this and clean it up.  EAGLE has a great
    alpha-blending engine that is pretty much ignored because it takes too much
    effort for most people to use.  And certainly noobs will have no idea on
    how to do all this.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    Take advantage of v7 License Promotion right now at
    http://www.eaglecentral.ca
  • paulr54
    0 paulr54 over 11 years ago in reply to autodeskguest
    James, thanks very much, that worked. You're right, that's a convoluted process to fix a simple problem. I hope CADSoft is listening.
