EAGLE User Support (English) Change package in one place and then update librarys where it is used.
  • Subscribers 181 subscribers
  • Views 350 views
bmoe
bmoe over 11 years ago
Hi.
I remember that I saw someone with a solution that you could change the PCB package in one "global" package library and then it got updated to all of your librarys where it was used.
For example if I got a SOT-23 package in four different librarys (transistors, diodes, linear regulators and sensors) then I would like to change the SOT-23 package in one place and then it got updated (with an ULP?) to the librarys where it s used.
Anyone know how to do this?
Regards
/Matias
    Former Member over 11 years ago +1 suggested
    Am 26.05.2014 11:20, schrieb Matias Sjögren: Hi. I remember that I saw someone with a solution that you could change the PCB package in one "global" package library and then it got updated to all of your…
    Hi.
    Regards
    /Matias
    You can change/copy your own package in the ref-packages.lbr, and then
    load libraries and UPDATE with ref-packages.lbr.
    HELP UPDATE
    The problem is, any manufacturer make different measure at the same
    package (SOT23, SOT89, QFPxx... on the data sheet).
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    EAGLE V6.5 availabe now!
  • bmoe
    0 bmoe over 11 years ago in reply to Former Member
    The reference library will only contain IPC7351A packages, and that will work in most cases, otherwise I will use separate packages in that specific library.
    I think that I have seen a ULP that will update all librarys with the packages from the reference library.
