EAGLE User Support (English) Does freerouter route ground pins when perfomring autorouting?
  • Views 1917 views
  • freerouter
Hi all,
I'd like to use freerouting.com's program to perform autowriting. I'm able to create the DSN file successfully after using the following .ulp file eagle2freerouter.ulp which I downloaded from the official Cadsoft downloads page.
I'm successfully able to successfully perform autorouting as per the following instructions.
Apologies if my question sounds basic but I'm unable to understand why the ground pins seem not to be routed. All my ground pins as per my .brd file in eagle contain airwires which I expect to be routed as the way eagleautorouter does it.
I've had a look at a board routed using freerouter as per this link and it is seems to me the groudn pins as per the attached files do not  contain traces running from them. Any idea why?
  • See attachment called unrouted .brd file in eagle for my unrouted .brd file in eagle.
  • See attachment called the .dsn file autorouted using freerouter for my .dsn file autorouted using freerouter.
  • See attachment titled EASYDAQ-XBEE v4sch.dsn to download my .dsn file.
  • See attachment called EASYDAQ-XBEE v4sch.scr this link to download my .scr file.
  • See EASYDAQ-XBEE v4sch.sch for my .sch file.
  • See EASYDAQ-XBEE v4sch.brd for my .brd file.
I appreciate any help.
Alex.
Message was edited by: Alex Monari
EASYDAQ-XBEE v4sch.scr.zip
EASYDAQ-XBEE v4sch.dsn.zip
    0 autodeskguest over 12 years ago in reply to e14 Contributor
    Hi Alex,
    [I can't see the screenshot as I stay away from google, but that does
    not matter]
    Sure, route the ground pins manually together, as I mentioned before I
    sometimes do that as I want to avoid that a (GND) polygon is broken into
    orphans. Make sure that you lock the GND wires before you autoroute, if
    you want to keep them they way you routed. But they are absorbed in your
    100% GND polygon coverage anyway.
    I just wonder why you cover top and bottom of a 2 layer board completely
    with GND polygons. Unless you have no significant other wiring, they
    will be cut up in pieces by the other signals anyway. you could place by
    hand via's to stich the 2 ground planes back up again, but that seems
    very tedious.
    Robert
    On 04/06/2014 14:13, Alex Monari wrote:
    Hi Robert,
    Based on your above comments would there be any issues/problems if I
    were to manually route the ground pins together as seen in this
    screenshot whilst I maintain the GND polygon I defined on both the top
    and bottom layers of the board?
    Here's the link to the screenshot:
    https://5a600546-a-62cb3a1a-s-sites.googlegroups.com/site/bgedsadata/HAND%20ROUTED%20GND%20PINS%20WITH%20GND%20ON%20TOP%20AND%20BOTTOM
    Apologies if the question sounds silly but I need to know before
    dedicating effort to routing the rest of the board.
    Alex.
    http://www.element14.com/community/message/115159
    0 e14 Contributor over 12 years ago in reply to autodeskguest
    Hi Robert,
    Based on your above comments would there be any issues/problems if I were to manually route the ground pins together as seen in this screenshot whilst I maintain the GND polygon I defined on both the top and bottom layers of the board?
    Here's the link to the screenshot: https://5a600546-a-62cb3a1a-s-sites.googlegroups.com/site/bgedsadata/HAND%20ROUTED%20GND%20PINS%20WITH%20GND%20ON%20TOP%20AND%20BOTTOM
    Apologies if the question sounds silly but I need to know before dedicating effort to routing the rest of the board.
    Alex.
    On 28/05/2014 11:53, Alex Monari wrote:
    Hi Robert,
    Thanks for the updated file. I've posted my reply here
    http://www.freerouting.net/fen/viewtopic.php?f=6&t=269 with links you
    can download the files. The forum didn't allow me to upload specific
    file extensions and I don't have zippinig software on my PC.
    Thanks.
    http://www.element14.com/community/message/114277
    Hi Alex,
    Just tested it, and it works OK. Since you have defined a "GND" polygon
    on both the top and the bottom layer over the whole board, the wiring
    signal "GND" is not routed, as it is already connected when loading the
    GND polygons.
    If you delete the two GND polygon definitions in the DSN file (wiring is
    the last segment of the DSN file), you will see that the GND signal is
    properly routed.
    Since signal polygons can breakup in routing, the eagle2freerouter
    converter allows you to specify the suppression of specific signal
    polygons (GND in this case) before Freerouter runs, forcing full routing
    of the GND signal. When loading the result into the Eagle BRD file, the
    polygons are added to get the copper back, but now you are sure that
    there are no orphan areas.
    The converter has a lot of options to add to the Eagle functionality,
    look in the heading of the ULP under User modifiable parameters.
    In this case, modify: string poly_drop = "";
    into: string poly_drop = "GND";
    R.
    Hi Robert,
    Thanks for the updated file. I've posted my reply here http://www.freerouting.net/fen/viewtopic.php?f=6&t=269 with links you can download the files. The forum didn't allow me to upload specific file extensions and I don't have zippinig software on my PC.
    Thanks.
    On 27/05/2014 17:46, Alex Monari wrote:
    Hi all,
    downloads page. (http://www.cadsoftusa.com/downloads/ulps/)
    following instructions. (http://www.freerouting.net/pages/eagle.html)
    file in eagle.
    scr file.
    • See attachment called EASYDAQ-XBEE v4sch.sch for my .sch file.
    • See attachment called EASYDAQ-XBEE v4sch.brd for my .brd file.
    I appreciate any answers.
    Alex.
    http://www.element14.com/community/message/114221
    Alex,
    You are using a very old version of eagle2freerouter.ulp, I have
    attached the latest version (April 19, 2014). As I do not have a Google
    account, I cannot download the .brd file, please post directly in the
    Freerouter technical support forum.
    The net names in the DSN file do not have quotes around them, which is
    not correct, and possibly caused by spaces inside their names.
    Robert
    eagle2freerouter19-apr-2014.zip
