EAGLE User Support (English) Polygon pours not accepting vias?
  • Subscribers 178 subscribers
  • Views 940 views
daemach
daemach over 11 years ago
In my older boards I use polygon fills around my regulators on both the top and bottom to act as a heat sink.  I then use a bunch of vias to connect them thermally.  It may be the new version of eagle that is causing a  problem, but these vias are ending up in unrouted layer with airwires even though they have the same name as the polygons (like ground plane vias).  The pour isn't working properly either.
Can someone please tell me what's happening here?
http://screencast.com/t/t6PQ4MVdA
AirNode - v5.1 (2).zip
    As far as I know, if you are in a restricted area the polygons can't pour.
    Marco
  • daemach
    0 daemach over 11 years ago in reply to autodeskguest
    Eagle seems to be treating the polygons as rectangles on a restricted layer.  Vias dropped within the polygon are showing up as restricted on the top and bottom layer.  This didn't happen in previous versions of eagle.
    0 autodeskguest over 11 years ago in reply to daemach
    eagle.
    If you turn off all layers except (1)Top and (41)tRestrict you will see
    there is a restrict area the same size as your polygon. The same goes
    for the bottom of the board with (16)Bottom and (42)bRestrict.
    How did that happen????
    So the fix is easy.
    Display only layer (41)tRestrict and delete the rectangle.
    Repeat for layer (42)bRestrict.
    HTH
    Warren
  • daemach
    Thank you very much.  How did that happen indeed...?  It has to have been a translation issue between 6.5 and the previous version.  I haven't run Eagle for over a year.  I upgraded then opened a file that used to work and here we are.
    I have no idea, but as you said, the fix is easy.  Thanks for taking the time to help!  I'll check the obvious next time.  Turning the restrict layers on after getting that message in DRC should have been the next step.
    It doesn't necessarily "have to have been" that...
    step.
    I believe there's been a change of behaviour in that older versions
    failed to perform restrict checks in DRC if the restrict layers were not
    shown. So the problem might have always been there but unnoticed.
    Anyway, glad you've got it sorted now.
    0 autodeskguest over 11 years ago in reply to autodeskguest
    Sorry - ignore my last post - I wrote it before my first cup of tea of
    the day and clearly wasn't thinking straight image
    step.
