EAGLE User Support (English) Pad name already exists
  • Subscribers 178 subscribers
  • Views 1001 views
I am attempting to create a 100 pin QFP 14mm x 20mm package.  I have all the pin locations in excel and then made the script below.  The problem is it tell me "Pad 'TS1' already exists" and then pops other naming errors up as well.  All the 'IC#' pins get a pop up error.  I sorted the name column and none of them are repeats...
[code]
SMD 0.015748031 0.070866142 ( 0.103346457 0.035433071 ) 'AMPOUT'
SMD 0.015748031 0.070866142 ( 0.128937008 0.035433071 ) 'AMPIN'
SMD 0.015748031 0.070866142 ( 0.154527559 0.035433071 ) 'AO1'
SMD 0.015748031 0.070866142 ( 0.18011811 0.035433071 ) 'AO0'
SMD 0.015748031 0.070866142 ( 0.205708661 0.035433071 ) 'TS0'
SMD 0.015748031 0.070866142 ( 0.231299213 0.035433071 ) 'TS1'
SMD 0.015748031 0.070866142 ( 0.256889764 0.035433071 ) 'BRD'
SMD 0.015748031 0.070866142 ( 0.282480315 0.035433071 ) 'VSS1'
SMD 0.015748031 0.070866142 ( 0.308070866 0.035433071 ) 'VCC1'
SMD 0.015748031 0.070866142 ( 0.333661417 0.035433071 ) 'SEL5'
SMD 0.015748031 0.070866142 ( 0.359251969 0.035433071 ) 'NC'
SMD 0.015748031 0.070866142 ( 0.38484252 0.035433071 ) 'RESET'
SMD 0.015748031 0.070866142 ( 0.410433071 0.035433071 ) 'XOUT'
SMD 0.015748031 0.070866142 ( 0.436023622 0.035433071 ) 'VSS2'
SMD 0.015748031 0.070866142 ( 0.461614173 0.035433071 ) 'XIN'
SMD 0.015748031 0.070866142 ( 0.487204724 0.035433071 ) 'VCC2'
SMD 0.015748031 0.070866142 ( 0.512795276 0.035433071 ) 'VCC3'
SMD 0.015748031 0.070866142 ( 0.538385827 0.035433071 ) 'STBY'
SMD 0.015748031 0.070866142 ( 0.563976378 0.035433071 ) 'NC'
SMD 0.015748031 0.070866142 ( 0.589566929 0.035433071 ) 'PWR'
SMD 0.015748031 0.070866142 ( 0.61515748 0.035433071 ) 'SUSP1'
SMD 0.015748031 0.070866142 ( 0.640748031 0.035433071 ) 'AS1'
SMD 0.015748031 0.070866142 ( 0.666338583 0.035433071 ) 'SUSP0'
SMD 0.015748031 0.070866142 ( 0.691929134 0.035433071 ) 'AS0'
SMD 0.015748031 0.070866142 ( 0.717519685 0.035433071 ) 'IC32'
SMD 0.015748031 0.070866142 ( 0.743110236 0.035433071 ) 'IC31'
SMD 0.015748031 0.070866142 ( 0.768700787 0.035433071 ) 'IC30'
SMD 0.015748031 0.070866142 ( 0.794291339 0.035433071 ) 'BRS2'
SMD 0.015748031 0.070866142 ( 0.81988189 0.035433071 ) 'BRS1'
SMD 0.015748031 0.070866142 ( 0.845472441 0.035433071 ) 'BRS0'
SMD 0.070866142 0.015748031 ( 0.913385827 0.11515748 ) 'DAOUT'
SMD 0.070866142 0.015748031 ( 0.913385827 0.140748031 ) 'DAIN'
SMD 0.070866142 0.015748031 ( 0.913385827 0.166338583 ) 'DACLK'
SMD 0.070866142 0.015748031 ( 0.913385827 0.191929134 ) 'DARTS'
SMD 0.070866142 0.015748031 ( 0.913385827 0.217519685 ) 'TXD'
SMD 0.070866142 0.015748031 ( 0.913385827 0.243110236 ) 'RXD'
SMD 0.070866142 0.015748031 ( 0.913385827 0.268700787 ) 'RDY'
SMD 0.070866142 0.015748031 ( 0.913385827 0.294291339 ) 'CTS'
SMD 0.070866142 0.015748031 ( 0.913385827 0.31988189 ) 'VCC4'
SMD 0.070866142 0.015748031 ( 0.913385827 0.345472441 ) 'NC'
SMD 0.070866142 0.015748031 ( 0.913385827 0.371062992 ) 'ACLR'
SMD 0.070866142 0.015748031 ( 0.913385827 0.396653543 ) 'IC0'
SMD 0.070866142 0.015748031 ( 0.913385827 0.422244094 ) 'NC'
SMD 0.070866142 0.015748031 ( 0.913385827 0.447834646 ) 'IC1'
SMD 0.070866142 0.015748031 ( 0.913385827 0.473425197 ) 'NC'
SMD 0.070866142 0.015748031 ( 0.913385827 0.499015748 ) 'IC2'
SMD 0.070866142 0.015748031 ( 0.913385827 0.524606299 ) 'STS'
SMD 0.070866142 0.015748031 ( 0.913385827 0.55019685 ) 'NC'
SMD 0.070866142 0.015748031 ( 0.913385827 0.575787402 ) 'PRD'
SMD 0.070866142 0.015748031 ( 0.913385827 0.601377953 ) 'IC3'
SMD 0.015748031 0.070866142 ( 0.845472441 0.681102362 ) 'NC'
SMD 0.015748031 0.070866142 ( 0.81988189 0.681102362 ) 'IC4'
SMD 0.015748031 0.070866142 ( 0.794291339 0.681102362 ) 'IC5'
SMD 0.015748031 0.070866142 ( 0.768700787 0.681102362 ) 'IC6'
SMD 0.015748031 0.070866142 ( 0.743110236 0.681102362 ) 'IC7'
SMD 0.015748031 0.070866142 ( 0.717519685 0.681102362 ) 'IC8'
SMD 0.015748031 0.070866142 ( 0.691929134 0.681102362 ) 'IC9'
SMD 0.015748031 0.070866142 ( 0.666338583 0.681102362 ) 'IC10'
SMD 0.015748031 0.070866142 ( 0.640748031 0.681102362 ) 'IC11'
SMD 0.015748031 0.070866142 ( 0.61515748 0.681102362 ) 'IC12'
SMD 0.015748031 0.070866142 ( 0.589566929 0.681102362 ) 'IC13'
SMD 0.015748031 0.070866142 ( 0.563976378 0.681102362 ) 'VCC5'
SMD 0.015748031 0.070866142 ( 0.538385827 0.681102362 ) 'IC14'
SMD 0.015748031 0.070866142 ( 0.512795276 0.681102362 ) 'VSS3'
SMD 0.015748031 0.070866142 ( 0.487204724 0.681102362 ) 'IC15'
SMD 0.015748031 0.070866142 ( 0.461614173 0.681102362 ) 'IC16'
SMD 0.015748031 0.070866142 ( 0.436023622 0.681102362 ) 'IC17'
SMD 0.015748031 0.070866142 ( 0.410433071 0.681102362 ) 'IC18'
SMD 0.015748031 0.070866142 ( 0.38484252 0.681102362 ) 'IC19'
SMD 0.015748031 0.070866142 ( 0.359251969 0.681102362 ) 'IC20'
SMD 0.015748031 0.070866142 ( 0.333661417 0.681102362 ) 'IC21'
SMD 0.015748031 0.070866142 ( 0.308070866 0.681102362 ) 'NC'
SMD 0.015748031 0.070866142 ( 0.282480315 0.681102362 ) 'IC22'
SMD 0.015748031 0.070866142 ( 0.256889764 0.681102362 ) 'IC23'
SMD 0.015748031 0.070866142 ( 0.231299213 0.681102362 ) 'IC24'
SMD 0.015748031 0.070866142 ( 0.205708661 0.681102362 ) 'IC25'
SMD 0.015748031 0.070866142 ( 0.18011811 0.681102362 ) 'IC26'
SMD 0.015748031 0.070866142 ( 0.154527559 0.681102362 ) 'IC27'
SMD 0.015748031 0.070866142 ( 0.128937008 0.681102362 ) 'IC28'
SMD 0.015748031 0.070866142 ( 0.103346457 0.681102362 ) 'IC29'
SMD 0.070866142 0.015748031 ( 0.035433071 0.601377953 ) 'PIO7'
SMD 0.070866142 0.015748031 ( 0.035433071 0.575787402 ) 'PIO6'
SMD 0.070866142 0.015748031 ( 0.035433071 0.55019685 ) 'PIO5'
SMD 0.070866142 0.015748031 ( 0.035433071 0.524606299 ) 'PIO4'
SMD 0.070866142 0.015748031 ( 0.035433071 0.499015748 ) 'PIO3'
SMD 0.070866142 0.015748031 ( 0.035433071 0.473425197 ) 'PIO2'
SMD 0.070866142 0.015748031 ( 0.035433071 0.447834646 ) 'PIO1'
SMD 0.070866142 0.015748031 ( 0.035433071 0.422244094 ) 'PIO0'
SMD 0.070866142 0.015748031 ( 0.035433071 0.396653543 ) 'SEL4'
SMD 0.070866142 0.015748031 ( 0.035433071 0.371062992 ) 'SEL3'
SMD 0.070866142 0.015748031 ( 0.035433071 0.345472441 ) 'SEL2'
SMD 0.070866142 0.015748031 ( 0.035433071 0.31988189 ) 'SEL1'
SMD 0.070866142 0.015748031 ( 0.035433071 0.294291339 ) 'AN3'
SMD 0.070866142 0.015748031 ( 0.035433071 0.268700787 ) 'AN2'
SMD 0.070866142 0.015748031 ( 0.035433071 0.243110236 ) 'AN1'
SMD 0.070866142 0.015748031 ( 0.035433071 0.217519685 ) 'AVSS'
SMD 0.070866142 0.015748031 ( 0.035433071 0.191929134 ) 'AN0'
SMD 0.070866142 0.015748031 ( 0.035433071 0.166338583 ) 'AVREF'
SMD 0.070866142 0.015748031 ( 0.035433071 0.140748031 ) 'AVCC'
SMD 0.070866142 0.015748031 ( 0.035433071 0.11515748 ) 'ADTRG'
[/code]
    Except I see I had multiple NC labels but I have fixed those and still get pop up errors during run...
    First off correct the script lines. The pad name should come after the SMD
    size .
    e.g. The first line should be
    SMD 0.015748031 0.070866142 'AMPOUT' ( 0.103346457 0.035433071 )
    HTH
    Warren
    0 Former Member over 11 years ago in reply to Former Member
    Am 02.06.2014 21:03, schrieb Luke Barker:
    http://www.element14.com/community/message/114911
    HELP SMD  -> SMD dx dy  'name' (x y);
    check the the name of NC...  VSS... VCC...
    The corrected script:
    GRID INCH;
    SMD 0.015748031 0.070866142 'AMPOUT' ( 0.103346457 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'AMPIN'  ( 0.128937008 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'AO1'    ( 0.154527559 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'AO0'    ( 0.18011811  0.035433071 ) ;
    SMD 0.015748031 0.070866142 'TS0'    ( 0.205708661 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'TS1'    ( 0.231299213 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'BRD'    ( 0.256889764 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'VSS@1'  ( 0.282480315 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'VCC@1'  ( 0.308070866 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'SEL5'   ( 0.333661417 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'NC@1'   ( 0.359251969 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'RESET'  ( 0.38484252  0.035433071 ) ;
    SMD 0.015748031 0.070866142 'XOUT'   ( 0.410433071 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'VSS@2'  ( 0.436023622 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'XIN'    ( 0.461614173 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'VCC@2'  ( 0.487204724 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'VCC@3'  ( 0.512795276 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'STBY'   ( 0.538385827 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'NC@2'   ( 0.563976378 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'PWR'    ( 0.589566929 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'SUSP1'  ( 0.61515748  0.035433071 ) ;
    SMD 0.015748031 0.070866142 'AS1'    ( 0.640748031 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'SUSP0'  ( 0.666338583 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'AS0'    ( 0.691929134 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'IC32'   ( 0.717519685 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'IC31'   ( 0.743110236 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'IC30'   ( 0.768700787 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'BRS2'   ( 0.794291339 0.035433071 ) ;
    SMD 0.015748031 0.070866142 'BRS1'   ( 0.81988189  0.035433071 ) ;
    SMD 0.015748031 0.070866142 'BRS0'   ( 0.845472441 0.035433071 ) ;
    SMD 0.070866142 0.015748031 'DAOUT'  ( 0.913385827 0.11515748 ) ;
    SMD 0.070866142 0.015748031 'DAIN'   ( 0.913385827 0.140748031 ) ;
    SMD 0.070866142 0.015748031 'DACLK'  ( 0.913385827 0.166338583 ) ;
    SMD 0.070866142 0.015748031 'DARTS'  ( 0.913385827 0.191929134 ) ;
    SMD 0.070866142 0.015748031 'TXD'    ( 0.913385827 0.217519685 ) ;
    SMD 0.070866142 0.015748031 'RXD'    ( 0.913385827 0.243110236 ) ;
    SMD 0.070866142 0.015748031 'RDY'    ( 0.913385827 0.268700787 ) ;
    SMD 0.070866142 0.015748031 'CTS'    ( 0.913385827 0.294291339 ) ;
    SMD 0.070866142 0.015748031 'VCC4'   ( 0.913385827 0.31988189 ) ;
    SMD 0.070866142 0.015748031 'NC@3'   ( 0.913385827 0.345472441 ) ;
    SMD 0.070866142 0.015748031 'ACLR'   ( 0.913385827 0.371062992 ) ;
    SMD 0.070866142 0.015748031 'IC0'    ( 0.913385827 0.396653543 ) ;
    SMD 0.070866142 0.015748031 'NC4'    ( 0.913385827 0.422244094 ) ;
    SMD 0.070866142 0.015748031 'IC1'    ( 0.913385827 0.447834646 ) ;
    SMD 0.070866142 0.015748031 'NC@4'   ( 0.913385827 0.473425197 ) ;
    SMD 0.070866142 0.015748031 'IC2'    ( 0.913385827 0.499015748 ) ;
    SMD 0.070866142 0.015748031 'STS'    ( 0.913385827 0.524606299 ) ;
    SMD 0.070866142 0.015748031 'NC@5'     ( 0.913385827 0.55019685 ) ;
    SMD 0.070866142 0.015748031 'PRD'    ( 0.913385827 0.575787402 ) ;
    SMD 0.070866142 0.015748031 'IC3'    ( 0.913385827 0.601377953 ) ;
    SMD 0.015748031 0.070866142 'NC@6'     ( 0.845472441 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC4'    ( 0.81988189  0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC5'    ( 0.794291339 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC6'    ( 0.768700787 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC7'    ( 0.743110236 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC8'    ( 0.717519685 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC9'    ( 0.691929134 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC10'   ( 0.666338583 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC11'   ( 0.640748031 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC12'   ( 0.61515748 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC13'   ( 0.589566929 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'VCC@5'  ( 0.563976378 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC14'   ( 0.538385827 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'VSS@3'  ( 0.512795276 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC15'   ( 0.487204724 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC16'   ( 0.461614173 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC17'   ( 0.436023622 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC18'   ( 0.410433071 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC19'   ( 0.38484252  0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC20'   ( 0.359251969 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC21'   ( 0.333661417 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'NC@7'   ( 0.308070866 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC22'   ( 0.282480315 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC23'   ( 0.256889764 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC24'   ( 0.231299213 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC25'   ( 0.205708661 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC26'   ( 0.18011811  0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC27'   ( 0.154527559 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC28'   ( 0.128937008 0.681102362 ) ;
    SMD 0.015748031 0.070866142 'IC29'   ( 0.103346457 0.681102362 ) ;
    SMD 0.070866142 0.015748031 'PIO7'   ( 0.035433071 0.601377953 ) ;
    SMD 0.070866142 0.015748031 'PIO6'   ( 0.035433071 0.575787402 ) ;
    SMD 0.070866142 0.015748031 'PIO5'   ( 0.035433071 0.55019685 ) ;
    SMD 0.070866142 0.015748031 'PIO4'   ( 0.035433071 0.524606299 ) ;
    SMD 0.070866142 0.015748031 'PIO3'   ( 0.035433071 0.499015748 ) ;
    SMD 0.070866142 0.015748031 'PIO2'   ( 0.035433071 0.473425197 ) ;
    SMD 0.070866142 0.015748031 'PIO1'   ( 0.035433071 0.447834646 ) ;
    SMD 0.070866142 0.015748031 'PIO0'   ( 0.035433071 0.422244094 ) ;
    SMD 0.070866142 0.015748031 'SEL4'   ( 0.035433071 0.396653543 ) ;
    SMD 0.070866142 0.015748031 'SEL3'   ( 0.035433071 0.371062992 ) ;
    SMD 0.070866142 0.015748031 'SEL2'   ( 0.035433071 0.345472441 ) ;
    SMD 0.070866142 0.015748031 'SEL1'   ( 0.035433071 0.31988189 ) ;
    SMD 0.070866142 0.015748031 'AN3'    ( 0.035433071 0.294291339 ) ;
    SMD 0.070866142 0.015748031 'AN2'    ( 0.035433071 0.268700787 ) ;
    SMD 0.070866142 0.015748031 'AN1'    ( 0.035433071 0.243110236 ) ;
    SMD 0.070866142 0.015748031 'AVSS'   ( 0.035433071 0.217519685 ) ;
    SMD 0.070866142 0.015748031 'AN0'    ( 0.035433071 0.191929134 ) ;
    SMD 0.070866142 0.015748031 'AVREF'  ( 0.035433071 0.166338583 ) ;
    SMD 0.070866142 0.015748031 'AVCC'   ( 0.035433071 0.140748031 ) ;
    SMD 0.070866142 0.015748031 'ADTRG'  ( 0.035433071 0.11515748 ) ;
    Alfred Zaffran
                                 Web:   <www.cadsoft.de>
    EAGLE V6.5 availabe now!
    0 Former Member over 11 years ago in reply to autodeskguest
    Yep that worked.  Sorry for the confustion, that was my first script.
