EAGLE User Support (English) PCB Tool > Statistics report in Imperial units
  • Subscribers 179 subscribers
  • Views 487 views
Version 6.5.0 PCB Editor > Tools > Statistics report has a lot of useful info, however, it is hard coded in mm units. Could this ULP be changed to include a selection for metric or imperial units ?
    Howard Davis wrote on Thu, 05 June 2014 15:39
    useful
    It would be better if the ULP queried the current grid setting and then
    used that.  That way it would be consistent with the way the rest of EAGLE
    handles units.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    Take advantage of v7 License Promotion right now at
    http://www.eaglecentral.ca
  • kikoun
    0 kikoun over 11 years ago
    I would prefer the James option (check the current grid setting), because what ever the default value of this option, I would never be the good one for half of users !
    Guillaume.
    0 Former Member over 11 years ago in reply to kikoun
    Hi James and Guillaume,
    I agree the ulp should read the Board grid units and report in those units.
    Opening the statistic-brd.ulp shows the author does suggest changing the units using the uval variable.
    Setting uval = 3, the statistic-brd.ulp does report all measurements in inches, except for the area measurements; they appear to be hard coded in mm.
    So, line 40 uval = 0 is Micron, 1 is mm, 2 is Mil and 3 is Inch.
    This is a workaround that makes this ulp quite useable.
    Perhaps the author can make the area measurements selectable.
    Cheers.... Howard
