EAGLE User Support (English) Eagle 2 Mentor Graphics PCB
  • Subscribers 187 subscribers
  • Views 1538 views
Hello
I have made a schematic in Eagle. Now I want to give that schematic to a
person who will make the board. The problem is he is using Mentor Graphics
PCB. Any idea on how to convert?
Peter
    Seems like me and the PCB layout designer have a solution on this. He had
    scripts/ulp files that generates the netlist and a part list. The problem
    with the part list is that I will have to manually choose the component in
    both Eagle and Mentor Graphics. So there is a correlation between the names
    Eagle use and the ones Mentor Graphics use.
    The answer why I am not doing the PCB layout myself is simply that the final
    device is needed to be small and fullfill some special requirements. Since
    the PCB designer that will do this for me has been doing this all his life
    and I am new, I simply knows he will do a better job and the final product
    will look better.
    Thanks for your replies
    Peter
    "Peter" <peter.jansson@broccoli.se> skrev i meddelandet
    news:gmhp73$glj$1@cheetah.cadsoft.de...
    Hello
    Peter
    Dave Pollum wrote on Fri, 06 February 2009 17:50
    On Fri, 6 Feb 2009 17:41:05 +0100, "Peter"
    <peter.jansson@broccoli.se> wrote:
    >Hello
    a
    Graphics
    I'm curious, why not design the board yourself?
    -Dave Pollum
    Hi Dave,
    I don't know why Peter is doing this specifically, but there are lots of
    companies that outsource layout.  They figure the system and circuit design
    are their core competency and thus create the schematic.  But they consider
    the PCB layout to be a commodity service that lots of people can do.
    I'm not saying I agree with this or that there might not be a better
    solution.  But some companies do think this.  That was the point of
    providing our PADS tool:  you can use EAGLE as a schematic capture package
    and then use a standard 3rd party interface for the layout.  And you can
    now license just the schematic capture module if you want which
    (apparently) wasn't possible before.
    Other times it is done because the designer just doesn't have enough
    bandwidth and it is easier to document this step of the process than
    embedded firmware, programmable logic, software, .....
    I'm sure there are others, but those are the two I see most often.
    Cheers,
    James.
    email:  sales2009@eaglecentral.ca
    fax:    888.701.8097
    web:    http://www.eaglecentral.ca
    Online EAGLE Dealer for US and Canada
    EAGLE Design Experts
    EAGLE Enterprise Toolkit
    Gary Gofstein wrote on Fri, 06 February 2009 14:33
    You could send them the netlist and the footprints for the devices you
    are using. That's all that's needed to make the board.  It will probably
    be far easier to just send him the schematic and redraw it in Mentor.
    Yes, you need a netlist and parts list.  But what format?  That is the
    question.  Anyone who is doing this professionally doesn't want to spend
    hours trying to get EAGLE to give the right format or the layout tool to
    read some aribtrary format.
    The PADS format is well documented and used by almost all CAD packages for
    this sort of design flow.  In fact, I know companies that have the entire
    Mentor toolset and still use PADS netlist to go from schematic to layout.
    There are better ways, but this one is proven if you are careful.  If you
    are not, it is fraught with peril.
    Cheers,
    James.
    fax:    888.701.8097
    Hello
    Peter
    -Dave Pollum
    peter wrote on Fri, 06 February 2009 11:41
    Hello
    Graphics
    Peter
    Hi Peter,
    I sure do.  Mentor PCB products will read in a PADS netlist, since Mentor
    now owns PADS.
    So you just need use our tool, EET: PADS Inteface, which will output a
    PADS netlist or ECO file for this very purpose.  It will also import a PADS
    netlist into the EAGLE PCB editor, but you won't need that.
    It is very reasonably priced ($100) and comes with support.  In other
    words, if you have an issue with it then we will help you through it.
    More info here
    http://www.eaglecentral.ca/forums/index.php?t=threadt&frm_id=15&S=90b575271a6ffc93371b0b843d5bd9df
    You can purchase it here
    http://www.eaglecentral.ca/purchase/eet_pads.php?product=1&d=1
    Cheers,
    James.
    fax:    888.701.8097
