EAGLE User Support (English) custom pad
  • Subscribers 179 subscribers
  • Views 410 views
custom pad
Hi all,
Im trying to create a USB connector, but having problems with yellow higlighted area. There is TH pad with rectangle shape. The hole is 1.5x0.825mm and I have no idea how to make pad like this in eagle.
There should be Top and Bottom layer and hole should be conductive. I've made small hack as is shown in last picture - there are three overlaping pads. But this is not a good solution image Can somebdy point me what is the best aproach to make a rectangle pad?
Hynek
    It may helpful if you provide a link to the data sheet you are using.
    Warren
    0 Former Member over 11 years ago in reply to autodeskguest
    Here is the link http://www.farnell.com/datasheets/1693470.pdf, part number is ZX62D-B-5PA8.
    H.
  • ootbrobo
    0 ootbrobo over 11 years ago in reply to Former Member
    This part is intended to be mounted by plated slots.
    From the Eagle manual
    My 2 cents, I would look for a part that either does not require such features, or I would determine whether a larger round hole could be used instead.  plated slots incur an up-charge at all the board houses I have used.  So I generally avoid components that require them.
    0 Former Member over 11 years ago in reply to ootbrobo
    Thanks a lot!
    Especially about up-charge in board house.
    Hynek
