    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
EAGLE User Support (English) Eagle 6.6.0 setgroup() ULP function
Autodesk EAGLE requires membership for participation - click to join
  • Subscribers 146 subscribers
  • Views 246 views
  • ulp
  • setgroup
  • select
  • group
sirpal
sirpal over 9 years ago
I have tried to run a 3rd party ULP to select components (i.e. parts) on schematic by command. Since it did not work, I tried debugging it backwards, and got to the point to realize that the setgroup() function does not seem to work on my installation(s). I actually stripped it down to the following ULP and tried it on 6.6.0 and 6.5.0, but didn't do anything.
It should select and add all parts into a group, but there is no group created at all.
if(schematic)
    sheet(S)
            S.parts(part)
                setgroup(part);
I attached the stripped ULP, and I call it from the schematic editor with "run select_all".
Is this only on my machine, or do others get the same result? Am I doing something wrong?
Thanks in advance,
Paul
select_all.ulp.zip
    0 autodeskguest over 9 years ago
    Review the attached file, which works
    The help for setgroup() says the object must be selectable.
    I suspect that a part is considered not to be selectable (it does not have
    xy coordinates and only exists once you place an instance of a "gate of the
    part". An instance is selectable and has xy coordinates.
    Hence the attached works.
    HTH
    Warren
    3326.select_all.ulp.zip
  • sirpal
    0 sirpal over 9 years ago in reply to autodeskguest
    Thank you very much for the help, I couldn't find any documentation about this change, that the parts are not selectable any more, just their instances.
    With this little tuning the special select script also works!
    Thanks for the help again!
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
