EAGLE User Support (English) The Title and Date in Frame
  • Subscribers 187 subscribers
  • Views 666 views
I have some problem to obtain title and date in frame.
The tutorial Eagle indicates >NAME >LAST_DATE_TIME variables.
How to do it?
Regards JF.
    On Tue, 17 Feb 2009 11:05:25 +0100, jfk1948 wrote:
    It seems it is not possible to affect them manually.
    I would think that if you went into the frames.lbr, you could delete the
    fields, which would leave them empty for you to fill in as you see fit.
    DMerriman
    "Dave Merriman" <dkmerriman@gmail.com> a écrit dans le message de news:
    gn8d20$uml$1@cheetah.cadsoft.de...
    On Sat, 14 Feb 2009 12:18:31 +0100, jfk1948 wrote:
    The tutorial Eagle indicates >NAME >LAST_DATE_TIME variables. How to do
    it?
    Regards JF.
    The frames I've used so far (A and B landscape) have included those
    variables. When you first load the frame and add parts, it looks like the
    date/name are empty, but as soon as you save the schematic with a name
    (then refresh the drawing), you'll see that they're filled in.
    DMerriman
    OK and thanks Dave,
    NAME >LAST_DATE_TIME variables are automatically affected at the time of
    schematic save.
    it?
    Regards JF.
    DMerriman
