EAGLE User Support (English) corrupted files from v5 to v6?
  • Views 405 views
I recently upgraded from Eagle v5.12 to v6.5.  If I use v6.5 to open a board file created in v5.x, it gets corrupted and I no longer have forward-backward annotation.  I did no editing, just reviewing.  Is there a way to fix this?  Has this been reported before?  Are there any other considerations involved in an upgrade?
    0 autodeskguest over 12 years ago
    Chris Isaacson wrote on Mon, 30 June 2014 09:08
    a
    any
    The first thing to repeat here is that a v6 file cannot be read by v5 so if
    you open an v5 file and save it back to the same location, it will be a v6
    file and you now can't open it in v5. So work with copies, keeping v5 and
    v6 separate.
    v6 validates more than earlier versions and so v5 files may have content
    that causes v6 to throw an error whereas they work fine in v5.
    Normally, from the error that is reported, you can locate the error in the
    v6 file, which is in XML format, and correct it.
    Have a go and post details/files if you are still having issues you cannot
    resolve yourself.
    Warren
  • AnalogNotes
    0 AnalogNotes over 12 years ago
    What do you mean by corrupted?  Is the file un-readable?  Does it contain garbage?  Or do you mean it doesn't pass ERC/DRC any more?  Cadsoft added some stricter checking in version 6.5, so some things that worked without error in 5.12 now get flagged.  I ran into this when I had different library names in the schematic and the board.  Each was valid by itself, but the latest versions of EAGLE check to make sure the names are the same in both the schematic and the board...
    If you run ERC, do you get errors?  What are they?
