EAGLE User Support (English) generate .rep file
  • Subscribers 178 subscribers
  • Views 630 views
generate .rep file
fablab48
fablab48 over 11 years ago
I need help with eagle, i need to generate file with the extention .rep
i don't know how i can do this
can someone help me
fab
    Hi Fabrice,
    I hope you're doing well. Unfortunately, in our industry extensions
    don't mean much. What does this file need to contain or represent?
    That will be helpful in determining how to generate the data you need.
    Best Regards,
    Jorge Garcia
  • fablab48
    0 fablab48 over 11 years ago in reply to autodeskguest
    Hi Jorge, thank a lot for your help.
    I have generated gerber files using the CAM processor , with gerber 274x and excellion.
    then i sent all to the manufacturer.
    he said me that he need a .TXT file with inside X, Y coordinates of all components designed on the PCB.
    i asked him to send me an example of such a file :
    look
    Implantation cms refusion
    vendredi 4 juillet 2014
    Nombre de composant : 46
    100MF-CHI16V   47.6250    61.9125    180.000   C6
    10-1206             44.1325     52.3875    270.000   R4
    BZV55C3.9        58.1025     44.4500    270.000   D4
    FDV304P          13.6525     74.9300    180.000   Q2
    100NF-1206       27.3050     80.6450    90.000    C12
    MIRE                49.5300     7.3025      0.000      S2
    0-1206-NE         57.4675     48.5775    0.000      R13
    1K-1206            54.2925     81.5975    180.000   R12
    i think this file is used to 'drive' an automatic machine that place components on the pcb.
    Jorge, could you help me, did you know this problem ?
    thank you
    fabrice
    placement XY.rep.zip
  • fablab48
    0 fablab48 over 11 years ago in reply to fablab48
    SOLUTION FOUND :
    open board:
    EXPORT Partlist
    or
    RUN mount.ulp | mount-marks.ulp | mount-marks-smd.ulp | mountsmd.ulp
    Alfred Zaffran
