EAGLE User Support (English) Wires vs Nets
  • Replies 8 replies
  • Subscribers 186 subscribers
  • Views 1517 views
Wires vs Nets
Former Member over 17 years ago
The manual says you must use the "Net" command to place nets.  It
explains the "Wire" command very little.  The help is quite abstruse
regarding the difference, but I seem to get the same results when I user
either: a wire with a net name.
When should I use "Wire" and when should I use a "Net"?
cheers,
Mike
    I think (just only think, but that's what I noticed):
    "Net" connects defined nets or pins and must have conntact to a pin (for
    example).
    A "Wire" can be everywhere and must not contact a pin.
    If you use "wire" to connect two pins, and the wire does not contact one
    pin, because you haven't clicked on the right place (maybe just beside
    the pin), you'll have no contact an EAGLE can't check this.
    So I use all the times the "Net".
    Daniel
    cheers,
    Mike
    "Daniel Vetter" <daniel.vetter@spacetec.de> a écrit dans le message de news:
    gnenva$jt3$1@cheetah.cadsoft.de...
    example).
    pin, because you haven't clicked on the right place (maybe just beside the
    Daniel
    cheers,
    Mike
    I readed in the manuals :
    " Do not use the WIRE command to draw net or bus lines in the schematic.
    Use NET or BUS instead!
    Net : Electrical connection in a schematic.
    Wire: Electrical connection in a board "
    Nets are nommed Airwires when you pass in the Board Editor for Route.
    After Route Airwires are converted to wires.
  • Richard_H
    Richard_H over 17 years ago
    cheers,
    Mike
    The NET command draws "nets" in layer 91 Nets automatically and
    supports the options "Auto end net" and "Auto set junction".
    See ==> Options/Set/Misc.
    WIRE is for drawing lines in any layer (for example for frames,
    additional art work in the schematic) and can be used in all layers.
    If you use WIRE in the Nets layer and start and end at a pin
    connection point it will result in an electrical connection, too.
    Richard Hammerl
    "Richard Hammerl" <ric@cadsoft.de> a écrit dans le message de news:
    gngf2o$rah$1@cheetah.cadsoft.de...
    cheers,
    Mike
    Richard Hammerl
    cheers,
    Mike
    Richard Hammerl
    OK Richard
    The definition of Net becomes clearer.
    but what is Airwire that in the Board Editor (wrote in the manual) ?
    airwires are unrouted connections.
    It's the unrouted net, acts as a "rubberband"
    r
    Ok as Kicad name "chevelu" in French.
    Thanks to you.
