EAGLE User Support (English) Grounding mounting hole pad?
  • Subscribers 177 subscribers
  • Views 353 views
I am looking for a lib with a hole/pad to provide for a 6-32 screw with
conductive pad for grounding.
    What about placing a via and use CHANGE diameter / drill to fit your needs?
    Gruß / regards
    Jörn
    with conductive pad for grounding.
    Just make it yourself -- very easy.  Simply a footprint containing one pad
    with size of hole and pad you want, a schematic symbol with one pin and
    maybe a circle to look like the hole, and a device to tie them together.
    Bert Menkveld
