EAGLE User Support (English) HostID is hardware dependant only ?
  • Replies 10 replies
  • Answers 2 answers
  • Views 1837 views
kikoun
kikoun over 12 years ago
As I said in the post 'New eagle licensing -> goodbye Eagle', I'm ready to purchase my V7 upgrade but only if I'm sure that the hostID is only link to the hardware and will not change if I install a new linux version. So my question is simple:
My computer run with linux, opensuse 13.1. In November, the opensuse 13.2 will be ready. Will the HOSTID change if I install this new OS on the same computer (usually I do not proceed with an simple update, I prefer to format "/" disk, and preserve only the /home disk).
  • kikoun
    0 kikoun over 12 years ago in reply to autodeskguest
    Hi Jorge,
    Is anybody could confirm that HOSTID is only  hardware dependent , or if
    it's OS dependent ?
    Guillaume Barrey.
    Hi Guillaume,
    I found out, the HostID is strictly hardware dependent. The OS doesn't
    play into the calculation of the HostID
    hth,
    Jorge Garcia
    That a great news for me, and now I'm OK for renewing my license because this mean that I could update my linux os without trouble.
    Thank you Jorge for your help.
    If I understand what Asko wrote, It's also mean that on my laptop, on witch I have a double boot linux Suse/ XP 32, I will have the same hostID  for both OS ?
    It's doesn't matter anyway if it doesn't, because I rarely use XP, but this will confirm that it really OS independent.
    0 autodeskguest over 12 years ago in reply to autodeskguest
    On 22.7.2014 22:59, Jorge Garcia wrote:
    On 7/21/2014 1:19 PM, Guillaume barrey wrote:
    it's OS dependent ?
    Guillaume Barrey.
    http://www.element14.com/community/message/121275
    Hi Guillaume,
    hth,
    Jorge Garcia
    I second.
    Same hardware works with different OS:es.
    Ok, I have tested it only Windows x32, x64, Debian Wheezy.
    Code may differ, but it has nothing to do with the Operating System.
    Yes exluding CPM, iRMX, HPUx, etc...
    I am sure license DO NOT work with XenServer either WMWare, but the
    multiple user license server may installed at them.
    Have a look the license model
    http://www.linqpad.net/Purchase.aspx#Multi
    Single license for three computers, license code checked via net, when
    activating.
    Possibility to transfer any of those license to the new hardware twice
    per year.
    Need no net connection when using software.
    Thank You Joseph Albahari, because Your licensing model is just as good
    as Your LINQPad. Used to use that everyday.
    I am working with two laptops and a desktop,
    Eagle license before 7, was suitable for hobbyist like me.
    Now I have to buy two licenses, because I am fixing JenDuino schematics,
    boards and software (At Home, At Play and At Cottage), before I can
    release it.
    This comment is only for single user license, the license servers and
    management is best for the big companies, who has replicated license
    servers and have > 10 seats.
      - Asko.
    0 autodeskguest over 12 years ago in reply to kikoun
    it's OS dependent ?
    Guillaume Barrey.
    Hi Guillaume,
    hth,
    Jorge Garcia
    0 autodeskguest over 12 years ago in reply to geoffriley
    Hi Guys,
    Geoff Riley prodded the keyboard
    Any idea if that is the case for GNU/Linux versions too?  No MS
    hardware scans to assign a convenient unique value in Suse or
    Ubuntu!
    As far as I am aware Linux uses component ID's in order to discover
    what hardware you have in order to select the correct driver for
    the things it knows about.  For instance if you have some obscure
    hardware, it likely doesn't work from the off !  This means that
    you have to search and find the right driver.  But I must admit
    Linux is getting very good at determining the right software to
    suit the hardware it finds.
    Now whether it keeps a list of these ID's or generates a key value
    for them, I don't know.  I do know that if you change a video card
    it will complain and then you have to sort out the driver for the
    new one.
    Best Regards:
                           Baron.
  • kikoun
    My question concern Linux. I run Opensuse, and I always install the last version of it (about once per year). That why I'm asking. I don't want to loose my Eagle license because I update my system.
    On MS, I prefer to avoid to re-install the OS : Too long, too complicated to keep your preferences, and to expensive to buy a new MS OS each year ( there is no new windows each year....) !
    On MS, If I had to re-install, is because the system became to dirty to work well...
    By the way, On MS, I know that some hostID used a number of the hard disk, but this number change when you format it. And even if it didn't, that stupid because the hard drive is the most fragile part of the computer !
    Unfortunately, if I remember correctly, changing a network or video card
    changes the ID for the way M$ calculates the ID and while these days, most
    of the motherboards have the network interface on them, changing video
    cards is not that uncommon.
    mikey
  • geoffriley
    0 geoffriley over 12 years ago in reply to autodeskguest
    Any idea if that is the case for GNU/Linux versions too?  No MS hardware scans to assign a convenient unique value in Suse or Ubuntu!
    Hi Guillaume,
    Guillaume barrey prodded the keyboard
    , or if it's OS dependent ?
    Guillaume Barrey.
    As far as I am aware yes it is hardware dependant and I belive it
    can be spoofed.  MS do a hardware scan and assign a unique value
    that represents all the checked components in a machine.  This
    creates a key that should be unique to only that machine.
    Best Regards:
                           Baron.
    it's OS dependent ?
    Guillaume Barrey.
    Hi Guillaume,
    I'll look into this and get back to you.
    Best Regards,
    Jorge Garcia
  • kikoun
    Is anybody could confirm that HOSTID is only  hardware dependent , or if it's OS dependent ?
    Guillaume Barrey.
